Old 12-20-2014, 05:40 AM   #1
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
Aluminium shaping
While researching riveting I found a site that I believe will be of interest to folks on this forum. I have no association with this site and am not benefiting in any way! I also did a search for it on AF and did not find any information. The site is Timmantech.com and its associated with aviation sheet meta work etc. Of specific interest was his tools associated with flow forming aluminium. He has rivet gun attachments that hammer metal. Achieving really consistent even results... Just thought I would share it and see if anyone had any experience with similar products or techniques. I will probably pick up a set and play with some banana wrap dents
Bullit is offline   Reply With Quote
Old 12-20-2014, 07:12 AM   #2
JCPOTTERF's Avatar
1963 28' Ambassador
Danielsville , Georgia
https://www.youtube.com/user/tinmantech
yep good video thanks
JCPOTTERF is offline   Reply With Quote
Old 12-20-2014, 07:34 AM   #3
Bullit's Avatar
1971 18' Caravel
Great videos on YouTube as well
Old 12-20-2014, 09:34 AM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The procedure he is referring to on the site is called planishing and will work well with the non tempered banana wraps, however do not attempt to planish tempered aluminum such as 2024-T3. Planishing can be done on annealed 2024-0 but will need to be heat treated which will result in 2024-T4.
These sites are very informative but sometimes they omit the alloy which is crucial in the forming process.
Old 12-21-2014, 06:09 AM   #5
Bullit's Avatar
1971 18' Caravel
Thanks Aerowood
Belly Pan Aluminium Streamsaver Belly Pans & Banana Wraps 5 09-08-2014 09:11 AM
Good forum for metal shaping. Eric H Ribs, Skins & Rivets 2 09-13-2011 10:11 AM
Shaping Subfloor Further99 Interior Restoration Forum 2 04-10-2011 07:26 PM
Styrene end caps for the aluminium bed extrusions chasgould Upholstery, Blinds, Walls & Interior Finishes 0 05-23-2004 04:23 PM
Living room is shaping up swebster General Motorhome Topics 48 02-23-2004 10:28 PM
