Old 07-27-2013, 08:37 AM   #1
2005 30' Classic S/O
Hockessin , Delaware
Alone grandmother needs help: AC intermittent
I am by myself expecting 4 small grandchildren in 2 hours. Airstream is in a campground. I came down yesterday and AC would not work. We have a Dometic Duo Therm with modes of fan, cool, heat pump and furnace. I have a local repairman come. He reset the circuit breakers, took off the interior cover and cleaned the filters. Air was working fine when he left. It was a cool day so I turned off the AC and left for a few hours. When I returned AC circuit breaker was off. I turned off the master and all other breakers (AC, hot water and one circuit with a white rectangular button) I turned them back on. Still have a problem. The zone 1 ( there is only one) is flashing and the air coming out starts out cool and then withing a minute turns very warm. I have the mode setting on cool and the fan on auto. Any suggestions as the repairman doesn't work on Saturdays.
dreamer60 is offline   Reply With Quote
Old 07-27-2013, 09:16 AM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It might be the campground power supply is overloaded because of hot weather and too many air conditioners running. This can lower the voltage you are getting, thereby increasing current and tripping the breaker. Can you have the voltage at your power pedestal checked?
doug k
Old 07-27-2013, 10:24 AM   #3
Thank you. I will check at the campground office.
Old 07-27-2013, 10:54 AM   #4
batman's Avatar
1964 22' Safari
modesto , California
Sorry you are having trouble. I agree with Doug, Have power/Amperage checked under load at the pedestal. If you have access to a good 30 AMP generator, try that.
-Dennis
batman is offline   Reply With Quote
Intermittent Brake Short Solved ddruker Brakes & Brake Controllers 1 08-12-2012 10:46 AM
Magnetek 3200 and Intermittent Power Jack 74 Ambassador Erik Olson Electrical - Systems, Generators, Batteries & Solar 3 04-02-2012 11:52 AM
Air brake warning intermittent landmarc Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 08-29-2011 09:33 AM
Intermittent speaker JBinKC Audio, Video & TV 5 01-14-2011 05:37 PM
