Old 01-18-2019, 08:57 AM   #1
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
All about showers
2019 Flying Cloud 26RBQ
I like a shower with good water pressure, but knowing I was moving into an RV I had diminished expectations.
With stock components, my shower enclosure is about six feet away and many 90 degree fittings and hoses from the pump. My flow is not a flow, but rather a pulsation when using the pump only. Changing to the much ballyhooed Oxygenics shower head, it is still a weak pulsation, and not enough pressure to push the water in a straight line across the enclosure.
With pump off and connected to the pedestal, the flow is even less than the pump. With only the internal pressure reducer, the flow is not enough to create a shower effect. With both a dial-pressure reducer at the pedestal set at 50#, and the internal pressure reducer, I get just a trickle.
Do you have a better experience with your rig?
What have you done to improve your flow? Surge tank? New pump? Other?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 01-18-2019, 10:04 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
No...we learned to adapt.👍
We never have taken a 'shower' in the AS. 😘
Go Navy, wet-off-soap&scrub-on-rinse-off, dry as needed.😂
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-18-2019, 10:10 AM   #3
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
We do have a better experience. When we are hooked to public water, we sometimes turn on the pump for more pressure (make sure you have fresh water in the tank). I have to believe you have a problem somewhere if you are not getting good flow from the shower. We seldom use the pump when hooked to the pedestal. I also have a filter and water softener along with my own regulator outside and that does not affect the flow that much.
You are getting enough hot water? What about your faucets? Are they getting enough pressure? If they are then maybe you shower control that mixes hot and cold is set wrong.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 01-18-2019, 10:58 AM   #4
1986 31' Sovereign
Miami , Florida
Something is definitely wrong. My Oxygenics shower head will pulse on the pump for a few seconds when first started but then provides a steady shower. On outside water, it works a mite better but not much.
Something is diverting or diminishing the flow -- do you have some kind of bypass for winterizing? (I live in Florida so I am vague on the winterizing process) Is pressure normal at the sink and in the toilet?
It's a puzzlement...
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-18-2019, 12:26 PM   #5
2018 28' International
Fayetteville , Georgia
The shower in my 28 Serenity works just fine. Not sure why my friends call me “Stinky”...
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 01-18-2019, 01:11 PM   #6
Mollysdad's Avatar
Yes.
I love my shower. It's one the the things that the 26 U designers got right (floor wise) Connected to city water the flow is comparable to home. I use the shut off to conserve water. I'm sure I used the pump for a shower, but I can't recall hating it, so I assume it was okay.
I turn on the water heater about 20 minutes ahead of showering, then turn the valve 3/4 of the way around until the hot water arrives, then back off a bit.
I wish I had better advice for you, but I haven't changed anything.
Old 01-18-2019, 01:24 PM   #7
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I hate to ask the obvious, but is the control on the shower handle in the full ON position?
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 01-18-2019, 05:10 PM   #8
2016 26' Flying Cloud
Southlake , Texas
We have never had an issue with water pressure in the shower with either campground water or freshwater tank. We did upgrade to the Oxygenics shower head, not so much because the factory shower head didn’t work, but because of the glowing Oxygenics reviews. It sounds like something is restricting the water to the shower if all the faucets have good pressure. Time for some diagnostics.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 01-18-2019, 07:18 PM   #9
Mollysdad's Avatar
First, let me ask, how is the water pressure at the sinks? If it's okay, I'd unscrew the shower head and remove the flow restrictor. Or, maybe a supply line is pinched.
I might have lower expectations, but I'd rather use my shower than any campground's.
If it's a 2019, I'd certainly not be shy about taking it to a dealer.
Old 01-18-2019, 07:35 PM   #10
Thanks everyone. Looks like I do need more troubleshooting. Nothing obvious when I trace the lines. I was planning on a Jackson Center tourist visit, perhaps I will get on their maintenance schedule.
Bill
Camp Host, Sandy Beach County Park
Rio Vista, CA
Want to be a camp host? Contact me.
WBCCI #6679
Old 01-18-2019, 08:21 PM   #11
2016 23' International
Loudon , Tennessee
Like the TN flag!
tomquinnjr is offline   Reply With Quote
Old 01-27-2019, 01:49 PM   #12
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
With my previous RV's (a SOB and an AS LY diesel pusher) I figured that the pulsation of water pressure when showering something I had to live with. But when I acquired my '87 Excella (in 2011) the PO had included, but not installed, a stainless steel accumulator tank - see https://www.campingworld.com/shurflo...ess-steel-tank - along with the Oxygenics shower head. No more pressure puslation and smooth showers while boondocking.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 01-27-2019, 02:00 PM   #13
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
We use the Furry by Oxygenic and it works very well. The original Oxygenic model is fine too, but we like the way the Furry model spreads out the water, still with good pressure. Much better than standard head that came with the AS. Sounds like your pressure issue may be somewhere in the lines...good luck.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 01-31-2019, 08:02 PM   #14
Poway , California
I agree, however, you could always trade your Airstream for a Winnebago, I heard they have high pressure showers... you city slicken’ yuppie, you!
RMMillerJr is offline   Reply With Quote
May Showers to Flowers wheel interested Our Community 14 03-24-2008 09:50 AM
Showers? 59as Sinks, Showers & Toilets 3 03-13-2008 06:07 PM
Don't miss Geminid meteor showers tonight maxandgeorgia Off Topic Forum 3 12-14-2007 01:48 AM
pre fab showers available? Tidal Sinks, Showers & Toilets 4 06-14-2007 09:14 PM
Summer meteor showers descend jpurdy Off Topic Forum 2 08-04-2004 10:35 AM
