Old 12-24-2015, 09:42 AM   #1
2012 30' International
Livingston , Texas
Alignment Question
I recently upgraded wheels and tires and was checking the clearance on the new Michelins between the front-most tires and wheel well. I have 1/4" clearance on the right side and 7/8" clearance on the left side. Would this suggest an alignment problem? Thanks.. I read these posts every day and have learned more than I can absorb.
Name:	Airstream wheel well space 002.jpg
ID:	254531   Click image for larger version
Name:	Airstream wheel well space 003.jpg
glenrms is offline   Reply With Quote
Old 12-24-2015, 09:48 AM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I don't think I'd use that gap as an indication of alignment problems. A more accurate gauge would be to measure the distance between the inside leading edge of a tire to the frame/wall of the wheel well and the inside trailing edge of the tire to the frame/wall of the wheel well.
Whats good for me may not be good for the weak minded.
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-24-2015, 09:54 AM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
This is as close to the front metal as the tire will get because it goes up and back when hitting a bump.
We had different width wheel openings on the 2015 23D and had to trim a couple of inches off the curb side to match the street side. Then the 15" LTX (P) 235/75R15 XL tires would fit.
Old 12-24-2015, 09:59 AM   #4
dznf0g's Avatar
Oswego , Illinois
Measure from the center of the coupler pocket to the some point on the axle ends. I think you'll find the body build to more off than the frame alignment.
-Rich-
Wheel/axle alignment question Gringo Axles 4 05-14-2011 08:02 PM
Hitch Ball Alignment mnikisher Hitches, Couplers & Balls 39 08-09-2005 02:29 PM
Alignment specs? Mark K Mechanics Corner - Engines, Transmission & More... 2 09-15-2003 02:24 AM
Axle Alignment Raptorrider2001 Axles 1 08-26-2003 06:20 PM
Bathroom Door Tracking Out Of Alignment montanaandy Doors & Locks 2 07-12-2003 02:47 PM
