Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-04-2014, 06:02 PM   #1
WorkofArt's Avatar
1976 31' Sovereign
Astatula , Florida
Airstream tilts to one side
I am a new airstream owner, and looking to redo my airstream as a man cave and put out by the pond in a permanent location. The airstream tilts to one side when on a flat surface. Can i just level this out when i get it to the permanent location or will this cause a problem down the road?
Just wondering if i need to take it in to have it looked at?
Also, wondering if anyone could recommend a good Airstream repair place in Central Florida in case i do need to take it in?
Thanks!!!!
WorkofArt is offline   Reply With Quote
Old 01-04-2014, 06:15 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
There is most definitely a problem. I would certainly have some one look at your axel. Sorry no knowledge of Florida service centers.
MICHAEL
Old 01-04-2014, 06:31 PM   #3
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I don't think it's a problem if you're not going to travel with it. You can always get it looked at if you decide to take it on the road in the future. Not sure if this is the cause of your tilt, but it probably needs new axles. It would be a waste to replace the axles if you're just going to park it.
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
