View Poll Results: What did you think of repairs you had done at Jackson Center?
LOUSY! They charged a lot and did not check their work!
1 |
3.70% |
Disappointing! Their work wasn't any better than local shops.
5 |
18.52% |
Okay, but I probably could have done just as well locally.
3 |
11.11% |
GREAT! They did everything as expected and charged less than local shops!
18 |
66.67% |
03-31-2010, 10:38 AM
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville
, Maryland
AIRSTREAM Service Center Poll
I recently picked up my 1998 Excella 34' after having a lot of different things done to it and have found that some of the most important repairs were done improperly and/or shoddily! Most importantly I had the roof sealed and the gaskets replaced on all the windows by the guys at Airstream - you would think that if anyone could do the work properly and make sure that it was not leaking it would be them! But did they? NOPE! My rear window let in water around the gasket to such an extent that the bottom of the drapes were wet, the wall wet to the touch and the table between the beds had a large puddle of water!
So, just what are we to do when we can't even take our trailers back to Jackson Center and get quality work done?
03-31-2010, 10:43 AM
Islay - 63 O.
Montreal
Are you still there? or around?
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
https://rvcampreview.com
03-31-2010, 10:52 AM
moderator
2016 27' International
Wilton
Did you contact someone at Jackson center about your dissatisfaction?
Im sure they are willing to correct it for you..
03-31-2010, 10:57 AM
1984 31' Airstream310
Ajo
Wow! I think that's the first badmouth I've heard of concerning Jackson. Maybe that was the first day on the job for the tech?
03-31-2010, 11:12 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
My experience at JC was just the opposite. We were very satisfied with all of the work that they did including leak fixes that have reappeared several years later.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-31-2010, 11:25 AM
_
Originally Posted by Mike Leary
Wow! I think that's the first badmouth I've heard of concerning Jackson...
not exactly...
my last repairs done in j/c included LEAVING TOOLs on the roof...
every day for 4 days.
even after pointing them out and ASKing to have the tools removed (i had no ladder)...
and being ASSURED "yes we took the tools off"
the tools were STILL UP THERE 1000 miles later.
__________
on the same trip the front beltline trim peeled away (it had be removed for repairs) after about a week of driving...
since 2 TINY pieces of double stick tape were all that was holding it on...
__________
had an AC unit replaced at j/c and a month later discovered that ANYTIME i pulled into a gfci type rv outlet, the breakers would trip...
a/s service center answer "modern trailers WITH gfci wiring cannot be plugged into rv parts with gfci on the post"
"GO TO OLDER CAMPGROUNDs" was the OFFICIAL advice from j/c.
1 year later and much $$$ later, they FINALLY agreed to check out the trailer wiring for issues...
turns out the tech (a 10 year veteran) had PINCHED wires in the airconditioner junction box and created the ground fault SHORT in my unit...
of course THEY didn't offer to pay for the mistake, mileage, time, inconvenience of this issue...
"sorry, we did THAT" was the only solace.
__________
others have reported problems here too, but the + reports far out weigh the -....
and many folks simply have such LOW expectations for rv service, such that ANY good works gets rave reviews...
OF COURSE the service center should do TOP NOTCH SERVICE, it's the friggin' factory HQ folks!
__________
the term "terrible" isn't how i'd describe their efforts...
but might express the frustration and disappointment with what was EXPECTED to be top notch repairs...
there is SO MUCH great positive posted about going to j/c here, that poor outcomes are REALLY disappointing when they happen...
__________
so YES bad service happens even at a/s h/q in j/c...
"what do you expect, they are built by humans, worked on by humans" is the excuse offered.
Originally Posted by GREENovaters
...My rear window let in water around the gasket to such an extent...
IF the gaskets are new, do some diy problem solving....
1. do they look evenly seated all around?
2. are there any GAPS in the gaskets (cut ends connected 2 each other)?
3. when the window is closed how LOOSE/SNUG are the turn latches (they may have been loosened 4 the NEW gasket thickness)
4. is the GLASS WINDOW/frame clean (is there glue or crud anywhere creating a gap)?
5. slip a dollar bill or piece of RIBBON into the window/gasket space then close....
this should NOT pull out easily, recheck every 4-5 inches around the perimeter...
one or both of the latches may need TENSIONING...
6. take some pics and post, visual clues may help solve the problem.
cheers
2air'
03-31-2010, 11:38 AM
1964 26' Overlander
Gloucester
, Virginia
This is why I do all my own work...if something is screwed up I only have myself to blame.
03-31-2010, 12:23 PM
2008 31' Classic
Lenoir City
, Tennessee
We had work done at JC last summer - primarily to repair window leaks, although there were a few other minor jobs as well. We had mixed feelings about the service.
First, the work took the expected two days, but we had to stay in a motel overnight instead of their campground because their transport tractor could not move our trailer around because they aren't familiar with our hitch type. (ProPride. Which we love, by the way, but JC's tractor boy wasn't comfortable hooking up to it.) So, our trailer stayed in the bay overnight instead of being moved back to the CG.
The work done on our windows was very poor. Didn't fix the leaks and was a messy, goopy caulk job. When I saw it I immediately went to a manager who agreed with me and made the service tech completely redo it.
There were a couple of other complaints I had, which a manager quickly responded to. However, I had to be assertive, watch-dog the tech, and insist on better work. Once I did, it was done. We all managed to remain civil to one another in the process.
I also had the benefit of the owner of the company who outfitted our trailer in the first place. He flew out to JC to meet us there and go over the work to be done with JC. I'm not sure how much of a difference he made, but, he did speak on my behalf a couple of times.
Our situation was a bit awkward at times. After all, JC provided the new shell, windows, etc., but another company did the inside. Our JC tech seemed to resent that fact - which I guess I understand since it meant that some of the work went elsewhere. But, I don't think that JC should frown at the opportunity to produce shells and ship them out for completion. That just sells more shells and opens up a new market. The management at JC was very positive about the whole thing; it was the shop tech that seemed to harbor the resentment.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
03-31-2010, 12:46 PM
1954 22' Safari
Deerfield
Originally Posted by 2airishuman
...the tools were STILL UP THERE 1000 miles later.
On the bright side... free tools!
03-31-2010, 01:29 PM
A.K.A "THE STREAM"
2010 25' FB International
Arlington
My thoughts Exactly!
Shane
03-31-2010, 02:06 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
We've been to JC twice for warranty work and everything was done well. Maybe after our experience at the Airstream dealer, any work would look good.
GREEN', have you contacted them about this? Are you still there?
Gene
03-31-2010, 02:26 PM
Ward
Although hearing only good to great reviews from jc, thanks for the input. This forum is the best!
I'm about to have solar installed on our Safari 25'. Any suggestions as to good techs/installers along Colorado's front range? ie.CO.Spgs to Ft Collins.
We'll be in the St. Charles, MO area near Bill Thomas Camper Sales if anyone has had work done there and if they know how to do solar.
Thanks, Cal
03-31-2010, 03:46 PM
Contact Rick March or Dave Schumann at the Service Center and let them know there is a problem and the details. Give them an opportunity before totally writing them off.
03-31-2010, 04:08 PM
NE
, Indiana
We had a dinette window replaced two, maybe three years ago at Jackson Center. When we got it home (outside in the sunlight) we could see that the tint in the new window was clearly much lighter than all of the other windows. My husband called the repair manager who essentially said, "Sorry, we did our best."
That was pretty unsatisfying. If memory serves me correctly, it was about $700 to replace the window.
We have considered getting the window tinted to match the others, but to me, that shouldn't be the route we have to go.
Randi
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
03-31-2010, 04:55 PM
_
no kidding and i've still got the sealant gun that was UP THERE...
the GOOD thing was...
nothing flew OFF while towing,
bashed in a windshield,
caused a wreck...
or KILLED ne1.
i was especially ticked about this because as i was LEAVING
i went in to the desk and told them what was up there and WHERE...
15 minutes later the desk gal came back and said...
"ok, someone just climbed up there and got the tools, u r good to go!"
________________
no one reporting negatives in THIS thread has written rick m. or you off, dave...
all day long u guys are fixin' stuff and dealing with customers who want the best work done...
some of those folks are WILLING to pay for it when needed.
and yes, MANY a/s owners are high maintenance, expect work for gratis and a fresh supply of 1967 knobs and fixtures...
so take the reports for what they are (a chance to improve) and try harder.
95% of the customer reports here are positive...
but jsut as kfrere notes, some of us have had to be ASSERTIVE, watch dog the tech and INSIST on better work...
not every owner is good at that and it's stressful for the customer to do THAT...
u guys have the upper hand and cannot afford to be lackadaisical.
________
lastly IF u guys can't sort out HOW TO PULL the trailer's that have a PROPRIDE hitch....
contact sean woodruff, i am ABSOLUTELY SURE he'd make/send you an adapter/stinger for this purpose...
you are gonna see a LOT more pp hitches and a growing number of them...
________
cheers
2air'
03-31-2010, 05:48 PM
2000 30' Excella
Kirkwood
, Pennsylvania
I have been at the Airstream Service Center for a number of issues in the past 2 years and have always left fully satisfied with the work preformed on both of my Airstreams and had everything from panel replacements to solar panel installation. I will be back in June for additional electrical items that I need to be installed and with discussions with Rick March, Dave and various Technicians at the Service Center I am confident that they will do an excellent job for me as they have in the past.
03-31-2010, 06:46 PM
1978 28' Ambassador
Morada
2air...many enlightening notes about your JC experiences - I can see how some are unhappy with their service experiences, as would I!...I'm sorry, if those things happened to me, I'd have a hard time going back to give them more of my $...at least without some measure on their part to set past 'problems' right...
In a lighter vein, I can't help to find it ironic, in this thread, that your Forum moniker happens to be: '2 air is human'.... No disrespect meant, it's just my warped sense of humor...
Keep up the good fight...
Ray
Ray & Pat; Morada, CA
03-31-2010, 07:23 PM
_
hiya mex'
my unit has had MANY repairs done in j/c...
while in warranty, i made 3? trips there and had 100s of things corrected...
and MOST were done properly, some BEYOND expectations.
most of the guys in the shop are VERY VERY good at what they do.
and i look forward to the guy how buggered the AC working on my unit,
because he's polite and listens and normally does good work.
but SHOULD the customer have to PAY for transport there to have THEIR mistake fixed?
i dunno.
like any shop they've got a couple of guys consuming OTHER PEOPLEs oxygen...
_________
but again it IS the corporate service shop and SHOULD set an example for all dealers and customers...
plus we all KNOW it's cool to take her back to the womb for work.
can't do that with most of our carsntrucks...
_________
btw air does not = err
common mistake but an error just the same...
_________
ok lets get back to helping the o.p. with da leaky windoz...
cheers
2air'
03-31-2010, 07:25 PM
Ajo
Being full-timers, I INSIST I be kept in the loop; it's our home, after all all. Thankfully, we have a great outlet up here and ditto in Phoenix, but I always keep my nose poked into what's being done.
03-31-2010, 08:16 PM
Dunsmuir
Mike,
Who do you use "up here", how about in Phoenix.
I found Oasis in Tucson to be excellent.
1984 310 Limited Motorhome
