Old 09-16-2012, 04:49 PM   #1
2008 22' Safari
Niskayuna , New York
Airstream Safari Skin Repair
Dear Airstream friends,
I have a 2008 Safari that was stored in a warehouse for the winter. The warehouse roof had a leak and caused some nasty problems with the A.S. skin. The skin had some white fungus on it which burned into the clear pretty bad.
I tried to wipe it off, clean it off, compound it off, but not luck.
so I tried to wet sand the skin lightly 2000 grit and it did not come off at all. I had to use 800 grit the problem area and removed the issue.
I am trying now to get the skin back to its oringal look. But no luck.
I clearcoated the skin after sanding the problem areas away. Please let mek know how I can get skin back to a shine without going to the dealship. LOL
Thank you for your help.
Classic79 is offline   Reply With Quote
