Old 02-02-2008, 09:54 AM   #15
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Thanks, gearheads! many good tips here I'd hadn't thought of...
for ex: I was just going to brush on my tile-doc-type epoxy white paint on the fiberglas bath sections but now that I have a decent compressor I'm considering getting a spray gun to shoot it on...depending on what this "water separator" will add to the cost of the rig...? I'm sure it would produce a smoother finish to shoot it on..
ditto on the impact-sockets, esp.since they only add 10-20 bucks or so to the cost of a socket kit vs. air ratchet alone...worth doing..
SmokelessJoe: can you try and reload that "t" photo or point me to it? when I click I get an 'invalid link' message... would like to see that..
Aerowood: yes, that 1/4" mini air drill is a beauty, I think there's one in one of your photos... safe to assume Chicago Pneumatic is a completely different manufacturer from the "Chicago Tools" we find at Harbor Freight I think? They sure look a lot more well-made..
and, yes, OV63, my 14.4 Milwaukee cordless drill has always been a faithful sidekick (scary to think how many drill bits that thing has been through...I gotta start buying more expensive bits...) but it large bulk makes it hard to fit in a tight squeeze. will probably be adding a mini-drill or rt.angle mini at some point...
I just realized how to create a wildly popular thread here...put the word "TOOLS" anywhere in the subject line. I'm kidding... but seriously, thanks for the tipsssssssssssssssssssssssssss...
fotochop is offline   Reply With Quote
Old 02-02-2008, 10:07 AM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A water seperator is generally $25-100, depending on how fancy you want to get.
Old 02-02-2008, 10:26 AM   #17
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
See if it works this time.....
Name:	air tools.jpg
Sergei
SmokelessJoe is offline   Reply With Quote
Old 02-02-2008, 11:27 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up very useful
Originally Posted by overlander63
Hmmm....
You will find all these tools useful, some more than others.
Air powered Long Neck de-capping tool, a must have!!
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 02-02-2008, 11:33 AM   #19
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Impact Sockets
They are measured in lb/ft of torque, and air consumption, @90psig.
One "know it all" I worked with used regular chrome plated sockets with his air gun, and one day the chrome started peeling off a socket. he didn't see it, and the chrome sliced his palm to hamburger in about a second.
So true. Impact sockets are a must! I should have mentioned that in my original post.
Vaughan
Old 02-02-2008, 11:44 AM   #20
1983 34' Excella
1967 24' Tradewind
Images: 32
Rivet Bottle Cap Wrench
Well, not air powered, but a good, solid, quality tool. Craftsman Capwrench Bottle Opener, 80th Anniversary - Model 44400 at Sears.com Mine isnít an 80th anniversary version, and I paid full price rather than the current $10.97. Itís truly a pleasure to take the cap off a St. Pauli Girl Dark with one of these.
Vaughan
Old 02-02-2008, 11:52 AM   #21
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Definitely a must for the good micro brews and imported. We call brews hydraulic sandwiches or barley pop at work
Old 02-02-2008, 12:51 PM   #22
1973 31' Sovereign
Portland , Oregon
Images: 22
I also already had a compressor when I bought my airstream. I think the only airtools that I had at that time were a brad nailer which I find invaluable for lots of things and a pnuematic sander. My compressor has trouble keeping up with the sander though. When I bought the airstream I went out to look for some inexpensive air tools. I found that there are a lot of combination kits out there that have anywhere from 4 to 6 different tools in them. I bought such a kit for just under $100. So far they have worked fine for what I need them for. My kit has an impact wrench which worked find for removing my Airstream wheels. It has a 3/8" socket drive with sockets which I used with good sucess on removing my axles. I snapped off an elevetor bolt when I was putting my floor back in so I did those by hand. There also is a cuttoff wheel that was a real life saver for getting the old subfloor out.
I bought a pop-rivet gun at Harbor Freight that is probably my most favorite Airstream related air tool. I also bought a small spray gun with a top mounted cup that I was able to use for spray painting my frame. I also may use for other things in the interior when I get to that point in my remodeling. I also bought a sand blasting gun at Harbor Freight that was supposed to work with my compressor but there just did not seem to be enough air flow to handle it. I have a second, larger compressor now so I will have to give that a try again. A sand blaster would be usefull for cleaning up your frame before painting.
For drilling I had an old Makita cordless drill/driver that bit the dust. I went out and bought a Black and Decker corded drill/driver for less than $40 that has been great. I like it becase the chuck for the drill bit pops off and exposes the screw driver bit. I have used it for all sorts of things besides my Airstream and would have to say that it was a very good buy. It has plenty of torque.
I still need a sheet metal shear but I am torn as to whether to go electric or air on this one. I have to shop around a bit and see when the time comes.
It is also pretty useful to have an air nozzel to blow things off with after you work on them. That and a shop vacuum cleaner have been very useful to me in my Airstream work.
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 02-02-2008, 04:04 PM   #23
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Air Tools
All the above is good stuff.
Never thought of the chrome coming off a socket while impacting...ouch.
Have had it come off, just not used in a air tool, luckly.
One surprize I had with a air rachet was how it can hammer your hand at beginnig of a tight bolt, or at end of tightening one.
It bam bam bam before you know it.
And they are very loud.
My order, based on size of your compressor...
Air Gun/nozzle with various tips
Die Grinder
Nailers/rivetor
Impact
About the time you use many of these, you will be wanting to move up in compressor size.
Lowes/Depot has a Air Tool set that come with many of these in one package.
For starting out, would be a good deal.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 02-02-2008, 06:49 PM   #24
crowbar68's Avatar
1975 27' Overlander
fort wayne , Indiana
tools
boy an air compressor will make you want to buy a whole lot more tools. a nibbler, shears, rivet gun, impact, drill, nailer, sand blaster, pressure blaster, bead blasting cabinet, air sprayer and an air dryer. when you get all that you might as well get a welder too.
you can never have enough tools.
" If everything is working, something is wrong ! "
crowbar68 is offline   Reply With Quote
Old 02-03-2008, 09:06 PM   #25
Thumbs up Tooltime
Ain't it FUN.........
PFC
"Tahawus"
RLC
John Prine
Old 02-03-2008, 11:13 PM   #26
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I'd rather use air
I was a Snap-On Tool dealer for seventeen years. During that time I learned a lot about air tools. I much prefer them over electric. They run cooler and are usually lighter than the same tool in electric.
You must know, however, that spinning tools such as grinders and buffers will use much more air volume than air hammers, chisels and even drills, as they are used for short periods, unlike buffers, sanders and spray equipment which are used continuously. A pretty high volume compressor is needed for those tools.
90 degree air drills are very handy and do fit into odd places easier than regular air drills. I use both.
As far as impact tools go, you should always use the black impact sockets on your impact wrench rather than chrome sockets. Chrome sockets are much harder and therefore brittle. The chrome can crack and peal causing injury, but the most failure comes from the socket breaking, sometimes with nearly explosive force. Also, the chrome sockets will cause premature wear on the impact mandrel, the part of the tool that you insert into the square in the socket. It is very easy to tell an impact wrench that has been used with chrome sockets, as the square part of the mandrel will have the corners worn off and become nearly round. Impact sockets will help prevent wear. The sockets are much cheaper than replacement mandrels.
A fun thing about air drills......they can be used under water. A customer of mine installed custom "swim steps" on large boats. He did it with the boat in the water. No haul out charge.
Old 02-04-2008, 03:47 AM   #27
Baltimore , Maryland
I love tools battery, corded and air... the one thing I have not heard is anything about hearing protection. I guess I assume that everyone knows how incredibly damaging the hiss of the air seeping from a loose fitting is. That high pitched air leak is kind if like a drill to your ear drums, so if the hose or fitting leaks, fix it. That annoying hiss will quickly become more and more difficult for you to hear.
I also would like to point out eye protection. I wear safety glasses all day. I sometimes forget I am wearing them and go places... I look more foolish than I already am wearing safety glasses to the liquor store or to lunch. I even wore them to an appointment once. Anyway, they suck. Safety glasses will allow chunks of things to bounce off your forehead and cheek and into your eyes. If one of those chunks sits in there overnight, well your eye might decide to grow around it. If that chunk happens to be a part of your frame, well it might start to oxidize and then you will need eye surgery. It gets tiring to explain how it happened to every nurse and every orderly and every doctor wants to know how you did that, most hospital people have no idea they still make "those". I now wear safety goggles and look ten times more geeky.
Old 02-04-2008, 09:05 AM   #28
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
The Problem with Nice Tools
I have a lot of Ingersol Rand air tools.I admire them
All the satety issues that surround them are real.Keeping them lubed is important,
having said that, when using air tools around anything that you will soon be painting, varnishing. Make sure to clean up well.It's amazing how a little air tool oil will "fish eye" your nice finish.Wipe down prior to paint is important.
And the other problem with them is they seem to grow legs, I've tried using mine with miniature "ball and chain" attachments but when working overhead I always seem to get whacked in the head.
my faves are, mini drill,90 die grinder, nibbler,3/8 impact,1/4 ratchet.
I had a electric angle like that milwaukee, best drill I've ever owned it was a Sioux I think, it walked away also.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Let the journey begin! crowldawg Member Introductions 4 09-11-2007 09:11 PM
newbie-where to begin? SafariSogood General Repair Forum 7 08-25-2007 02:01 PM
Where to begin? Jolly Roger 1972 Overlander 7 06-26-2007 12:23 PM
LP Powered Air Conditioning moosetags Furnaces, Heaters, Fireplaces & Air Conditioning 12 11-12-2006 05:56 PM
I don't know where to begin - part I susie Our Community 6 09-24-2002 08:26 AM
