Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-26-2012, 05:45 PM   #1
1971 23' Safari
Mobile , Alabama
Air Conditioner not cooling
The air conditioner fan in my '71 Safari Twin runs on low and high, from the sound the compressor comes on, but the air is barely cool. Could this be as simple as being low on freon?
I've heard that the rv air conditioners are sealed and freon can't be added.
Any ideas or suggestions?
theterrells is offline   Reply With Quote
Old 04-26-2012, 06:30 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Air Conditioner not cooling Reply to Thread
Greetings theterrells!
If your air conditioner is the original Armstrong Bay Breeze or similar Armstrong model, it is serviceable and nearly every component is either rebuildable or can be replaced. This is a unique feature of the Armstrong air conditioners originally intalled in Vintage Airstreams. The challenge is usually finding someone who is willing to perform the service as most RV Techs just shake their heads and tell you the unit is not repairable due to its age. I learned too late too ignore the typical RV Tech response and allowed my Armstrong to be replaced that likely just needed two components and a recharge. Try searching for a commercial refrigeration technician who might be willing to service your Armstrong.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 04-26-2012, 08:05 PM   #3
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Actually thats what I need to do with mine. Is to have it re built.
https://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-27-2012, 04:27 PM   #4
jmpratt's Avatar
1969 29' Ambassador
Liberty Township , Ohio
It is probably low on refrigerant. Call a local A/C service company and they can work on it. Automotive A/C guys don't seem to really know much about A/C systems. Also, that unit has R-22 which most auto guys don't have.
-Jason
jmpratt is offline   Reply With Quote
Old 04-27-2012, 06:49 PM   #5
Kenner , Louisiana
I am a commercial A/C tech and if it is the older unit I would repair it just for the originallity of it. If it is a newer unit with more than 10 years of age, get a new one. The newer units are very cheaply made, I probably do not need to state that. Get a home or comercial tech if you go the repair route, an auto guy will probably be lost.
I wish you lived a little bit closer than Mobile.
fourcatos is offline   Reply With Quote
Old 04-28-2012, 03:32 PM   #6
1971 23' Safari
Mobile , Alabama
How secure is the top of an AS? On our old box trailer we would lay some 1/2inch plywood on before getting on top. Can I just climb around on the top of the Airstream?
Old 04-28-2012, 03:48 PM   #7
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Stand on the rivet lines(the ribs). Don't think I would put down any plywood up there. Good luck, and don't fall off. Wear some tennis shoes.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
sandlapper is offline   Reply With Quote
Old 04-28-2012, 03:50 PM   #8
sandlapper's Avatar
1993 34' Excella
....and don't climb up on the end caps. Put the ladder against the awning. And pad the ladder.
John
Old 04-29-2012, 06:14 AM   #9
Kenner , Louisiana
Watch utube video on airstream ac replacement. DIY network did a lot of good shows on airstreams
