Old 01-04-2016, 05:58 PM   #1
Levelland , Texas
Air Conditioner/ furnace problems
My thermostat shows 32 degrees on Zone 2. The AC will not cool and the furnace will not shut off. I had the control board on the AC replaced and it worked for a week. Now it is showing 32 degrees again.I can flip the battery disconnect switch to on or off and it works fine for a few hours then back to 32 degrees. I am the second owner of a 2014 International Signature Onyx ,So no help from Airsteam or Dometic. All help will be appreciated. Thanks
Troy Tyson is offline   Reply With Quote
Old 01-04-2016, 06:42 PM   #2
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Hi Troy. Have a look at my posts starting December 24 pertaining to the AC and then December 29 pertaining to the furnace. Both are now operating, I think, since the AC was running when I was south and I did get the furnacing running now that I am north. Very interesting that our units would have identical problems. Jim
Jim Flower is offline   Reply With Quote
Old 02-02-2016, 06:56 AM   #3
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
did you figure out the issue?? guess I have to read the post to see.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 02-04-2016, 12:44 PM   #4
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
I am not sure if the issue is truly resolved since we are in hibernation mode. Have a gander at the posts. I am cautiously optimistic that we have air and heat. Jim
Dash Air Conditioner Problems Santart Land Yacht/Legacy Motorhomes 4 09-05-2012 01:54 AM
Air Conditioner Problems Surfairstrea Furnaces, Heaters, Fireplaces & Air Conditioning 12 09-13-2011 08:12 PM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
air conditioner problems,help! art Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-05-2006 02:59 PM
New Airstream - Air conditioner/Furnace problem mariffe Electrical - Systems, Generators, Batteries & Solar 12 04-16-2003 04:26 PM
