Old 06-12-2013, 06:46 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
air conditioner for '65 Overlander
I am about to buy a 65 overlander, wondering if a dometic penguin 13,500 BTU a/c would be enough to coolit? I live in OK,so it gets hot here!
Cochese is offline   Reply With Quote
Old 06-22-2013, 07:02 AM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
13,500 BTU may be too big a unit - that's the size in my 32-ft Excella and it cools it down very well. The problem is that if the unit's capacity is too large, it will cool down so rapidly that the humidity will not be removed. My suggestion FWIW would be no greater than 11,000 BTU.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 06-22-2013, 07:48 AM   #3
Central , Mississippi
The 14,000 in our 29' was NOT big enough. I just installed a 15,000 on our '63 Overlander and so far its been a good choice.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-22-2013, 08:07 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Go with a 15000, Tulsa in the Summer?....Go with a 15000.
Old 06-22-2013, 11:21 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
air conditioner for 65 overlander
Greetings Cochese!
I have a 13,500 btu Coleman in my Minuet and it handles the 20-foot coach with ease in the very humid conditions of far Southern Illinois and nearby locations. My '64 Overlander has a 15,000 btu Coleman air conditioner, and I wouldn't want anything less in this humid climate.
Good luck with your investigation!
Kevin
P.S.: If your Overlander has an original Armstrong Bay Breeze air conditioner, you may want to consider seeing if a commercial cooling repair person can repair it as these were very heavy duty units and were made to be easily serviced by someone familiar with commercial cooling units. An RV air conditioning repair person isn't likely to be familiar with the hardware in the Armstrong units. I didn't learn this until too late on my Overlander or it would still have its original Armstrong Bay Breeze.
Kevin D. Allen
AIR #827
Old 06-22-2013, 12:16 PM   #6
Crusty's Avatar
1992 34' Excella
Yup, in the south there's hardly ever any worry about an a/c cycling too quick (maybe in January ☺). I got a 15K for my 34' and I'm glad I did.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Dash Air Conditioner Problems Santart Land Yacht/Legacy Motorhomes 4 09-05-2012 01:54 AM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
