Old 05-13-2016, 10:28 AM   #71
2014 30' Flying Cloud
Ponce Inlet , Florida
XX on sealtech leak check.. We think of it as cheap insurance and piece of mind. We have ours done annually at JD Sanders near Gainesville FL it was either $100 or $125. I don't like going on the roof so I have them pull the both ac covers to check for mudobbers, any other debris and check the drain lines also have them inspect caulking and seams while they are up there. I think that added about $ 75 to the bill.
Beach Bum is offline   Reply With Quote
Old 05-13-2016, 01:07 PM   #72
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
In used to the roof now but it always is a tedious matter
https://youtu.be/UlkV4tXWlFc
PharmGeek is offline   Reply With Quote
Old 05-17-2016, 12:46 PM   #73
Kellerzal's Avatar
2012 25' International
Olympia , Washington
Pollen
You aren't kidding about that pollen - I too waited a bit too long to wash and it took me all day to get it clean(ish). Had to do the toothbrush thing for the silver strip that has the bevels in it. Found out that an old Sonic Care tooth brush works really well to get into some of those cracks! Thanks for the post!
Kellerzal is offline   Reply With Quote
Old 05-17-2016, 02:38 PM   #74
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
The nooks between the window rubber gaskets and window aluminum frame filled with pollen -
O. M. G.
Ok I'm done - clean regularly! Now I'm like "hmmm - maybe twice a month"
Old 05-21-2016, 02:00 PM   #75
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Without reading any responses, I say make sure that the inside stays dry, keep the pipes and tanks from freezing, and fix what breaks as it breaks.
Superat stultitia.
Yearly inspection CANADIAN BOB Member Introductions 4 06-23-2007 07:42 AM
Looking for yearly stay in Florida Daisy2 On The Road... 4 10-05-2006 10:32 PM
Suburban NT32 Maint Pick Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-16-2003 07:43 PM
'81 454 prevenative maint. & upgrades IPM Mechanics Corner - Engines, Transmission & More... 10 09-02-2003 10:29 AM
Preventative Maint. Daniel Conroy 1987 - 1989 Excella 7 01-20-2003 08:48 AM
