Old 03-08-2009, 11:09 PM   #1
Olympia , Washington
Adhesive for rub rail on 2006 Safari
Well, we just purchased a '06 25' Safari SE FB and are enjoying the heck out of it. This is also my first post on the forums. I really love this site. I have a rub rail that is coming a bit loose and I want to know what the appropriate adhesive is for it and the best method for reattachment. I have some Sikaflex 221 that I bought from AS. Here is a better pic so you know what I am talking about. Thanks in advance!
ID:	76612   Click image for larger version
sirws is offline   Reply With Quote
Old 03-08-2009, 11:19 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Welcome Sirws, and congrats on all accounts!
I've use contact cement on my rub rail. Be sure to let it tack up as per the instructions.
Is there double sided sticky back on the insert?
Maybe others know some other method. I'm sure they will chime in....
Welcome to the adventure!
Michael
ArtStream is offline   Reply With Quote
Old 03-09-2009, 04:57 AM   #3
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Sirws,
I had to replace some of the same stuff on our '06 Classic becuase some of the plastic chrome started to bubble and I did not like the looks of it. It was still under warranty when it happened. If I remember correctly it is just 3M double sided tape on the back. Remove the old trim piece, strip the adhesive from the trim strip and the trailer, and clean both surfaces. Then go to Home Depot or similar store and get some 3M double sided tape and you should be in business.
If you need fresh trim you can get some at Out of Doors Mart...
1 inch
Molding 1 inch Chrome Rub Rail SKU9099 - $2.49 : ODMRV , Out-of-Doors Mart
1/2 inch
http://odmrv.com/catalog/index.php?m...roducts_id=572
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Beltline/Rub Rail George Clearcoat, Exterior Paint & Trim 11 02-20-2017 05:22 AM
Need help w/ rub rail RiskIt Clearcoat, Exterior Paint & Trim 3 07-24-2005 09:52 AM
blue rub rail paul k Clearcoat, Exterior Paint & Trim 0 04-27-2003 12:52 PM
