Old 07-26-2019, 01:42 PM   #1
2003 31' Classic
Sioux City , Iowa
Adding Second Air Conditioner
We would like to replace the Fantastic Fan in our Classic with an air conditioner. In reading about this project, we are learning about a condensation tube that runs through the walls so that the condensation does not drip off the exterior of trailer. Is this correct? If so, is there an alternative to the condensation tube through the walls? Thanks in advance for any help.
Nosernos is offline   Reply With Quote
Old 07-26-2019, 02:49 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You will have to take the trailer up to 50A electrical for two A/C's. Doing that wiring involves a lot more this and that than running the drain tube does.
The alternative is to just let condensation run down the outside of the trailer. It looks ugly, but it works.
Old 07-26-2019, 03:45 PM   #3
2019 27' Globetrotter
Missouri Valley , Iowa
The draining condensate running down the side of your unit WILL look ugly. As I understand - it will eventually etch the clearcoat on your trailer.
Dan
Farmer Dan is offline   Reply With Quote
Old 07-26-2019, 04:40 PM   #4
Central , Mississippi
I added a second AC to our 34 (why did they ever make a 34 trailer with one AC???). I was able to route the drain forward to the bathroom, down the vent cover, over and down thru the sink cabinet and out the wheel well. I added a second breaker panel in the street side floor cabinet with a second inlet at the rear corner. Regularly run it on a 20 amp outlet. I also decided on a 11k btu unit to minimize cycling. I think my 34 thread is where the photos are.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Anyone added a second air conditioner? kdinnar Electrical - Systems, Generators, Batteries & Solar 13 06-11-2018 12:39 PM
2016 Second Air Conditioner not cooling Llando88 Furnaces, Heaters, Fireplaces & Air Conditioning 27 03-20-2018 04:14 PM
Adding an Air Conditioner to a 1963 Overlander kweinrich Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-25-2016 07:44 PM
Add a second air conditioner to a 27' or 28' AS johnlanglois Furnaces, Heaters, Fireplaces & Air Conditioning 12 12-13-2014 04:39 PM
Removing the Air Conditioner and adding a skylight Brian Schulz General Repair Forum 2 06-13-2014 08:43 AM
