Old 05-05-2012, 06:27 AM   #1
1975 29' Ambassador
Mustang , Oklahoma
Adding a drain plug to fresh water tank...
Our vintage airstream does not have a fresh water tank drain plug installed. I am wanting to add one to make it more easy to clean and maintain.
Anyone have any recommendations and/or experience with this?
We have a 1975 Ambassador.
Bambi
bambid is offline   Reply With Quote
Old 05-05-2012, 08:14 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It should have a drain valve installed on the feed line. If not...just put one in the line there.
Old 05-06-2012, 06:07 AM   #3
1975 29' Ambassador
Mustang , Oklahoma
Could you please make a recommendation on what type/brand to use? Where to find one? Etc...
bd
Old 05-06-2012, 07:06 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If the plumbing hasn't been monkeyed with, you should find three low point drain valves below the floor under the kitchen cabinet. One of those is the drain for the fresh water tank. Simply follow the feed line down from the water pump to the tank, and you should run into the valve.
