Old 04-23-2016, 08:55 AM   #1
2000 19' Bambi
BOZEMAN , Montana
AC Shroud Replacement
I just received a replacement shroud for the AC unit on our 2000 19' Bambi from Icon. The shroud appears to be made of a better material, but the rear screw holes are 1/4" forward of where they should be and the shroud did not come with the foam tape that routes air flow around the condenser.
Does anyone know where I can purchase replacement foam tape? I checked the local ACE Hardware and they do not carry it.
Thanks for your help, Bob.
BobBozeman is offline   Reply With Quote
Old 04-23-2016, 09:07 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Loews or a local commercial HVAC supply.
MICHAEL
Old 04-24-2016, 05:30 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I've purchased stick-on foam weatherstripping tape at Homey D.
Old 04-24-2016, 07:13 PM   #4
dznf0g's Avatar
Oswego , Illinois
Yup, me too
-Rich-
Old 04-24-2016, 07:54 PM   #5
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
the weatherstripping to use is 1 1/4"x 1 1/4" also used for room Airconditioners. Anything smaller may not seal properly
http://www.ebay.com/itm/1-1-4-x-1-1-...wAAOSwPe1UEhuB
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 04-25-2016, 08:18 PM   #6
2000 19' Bambi
BOZEMAN , Montana
Thank you for the responses. I think I'll use the room AC 1 1/4" foam with some double stick tape.
I got an interesting response from ICON when I asked them about the foam:
The foam tape in not a necessary to have, however if you would like it for you replacement shroud, some customers have used the original foam from the original shroud or found something similar at the local hardware store.
It's hard to believe that the AC unit would be as efficient if you skipped using the foam. Proper air flow around the condenser is pretty important.
Thanks again, Bob.
Replacement shroud for Coleman Delta TX a/c blackbird Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-03-2013 06:55 AM
1988 Excella Shroud Replacement Needed Airstruck General Repair Forum 2 10-04-2012 06:00 PM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Installing Roof Air Replacement Shroud Kajendo Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-30-2008 12:20 PM
A.C. replacement shroud? krazeekalvin Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-27-2007 12:36 PM
