Old 05-29-2012, 08:04 PM   #1
2011 23' International
clovis , California
Angry AC not cool
My AC is running, but blowing air just slightly cooler (or possibly the same temp) than the outside temp. Thermostat seems to work. It clicked off at night when it cooled naturally and clicked back on when temp came up. Where should I start?
jgerardi is offline   Reply With Quote
Old 05-29-2012, 08:47 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
First you have to determine if the compressor is in fact running. The easiest way, if you can not hear it come on, is with an amp meter. Measure the current while the fan is on and then when the unit is calling for cooling.
If the compressor is working and not cooling I suspect you have lost the gas charge in the unit.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 05-29-2012, 09:10 PM   #3
clovis , California
Thanks Wally. A good place to start!
Old 05-29-2012, 09:33 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I would start with sticking a thermometer in the A/C vent; Mine goes down to about 40 degrees.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
