Old 08-15-2011, 03:43 PM   #1
Voyager407's Avatar
Orlando , Florida
Unhappy AC Hum from Stereo Speakers
I am presently traveling in a 2000 Land Yacht 390 XL. The speaker system has a push-button that powers a three-position switch: Stereo, Video, and Off. The speaker system and the radio itself are 12v DC and operate fine when we are dry camping. However, when we are connected to AC power, there is usually an awful AC hum when we are listening to the radio and have the speakers set to Stereo. (You can't hear the radio if you switch the external speakers off.) Sometimes the hum is so loud that you can't enjoy the music at all! Most of the time, if we switch the radio off, the speakers STILL emit this awful hum!
I know this sounds like a ground loop problem, but why is there no hum when we watch and listen to the TV (broadcast, cable, or DVD) through the same speakers set to Video?
I would appreciate any advice you might have.
Voyager407 is offline   Reply With Quote
Old 08-15-2011, 04:32 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
My first guess would be ac coupling directly into the radio antenna from the convertor. Try disconnecting the convertor while the radio is on and the hum is there. If the hum goes away trace the antenna wire and see if it comes close to the convertor.
2004 Excursion 4x4
Old 08-22-2011, 10:57 AM   #3
wlj1943's Avatar
1970 18' Caravel
Mulino , Oregon
Defective diode in the OEM Magnetek converter converter can cause this.
wlj1943 is offline   Reply With Quote
speakers, stereo, air conditioning
Clipper, Land Yacht, Radio TV Speakers masseyfarm Audio, Video & TV 2 06-23-2013 10:49 PM
The Hum is (was) back RichHog Audio, Video & TV 11 03-16-2013 12:39 PM
HUM from radio when hooked to shore power The Driver Audio, Video & TV 5 07-12-2011 05:42 AM
Playing iPOD through stereo sweetsilver Electronics & Connectivity 11 05-14-2011 10:31 PM
2 questions about lcd installation. Speakers and vibration mikeandnora Audio, Video & TV 5 05-04-2011 07:08 AM
