Old 11-22-2016, 04:12 PM   #1
2014 30' FB FC Bunk
City , Maryland
AC/Heat Pump Drain Line Connector Broken
Ok airstream gurus how do I fix this? Broken connector on the drain cup line that passes thru the gasket and connects to the tube that goes down the wall ! I noticed that ac was draining down the front of the camper, so I pulled the shroud down from the inside ceiling. Pulled on the line and this is what I found. Just lucky that the drain cups seem like their plugged. Tubing is bone dry. Click image for larger version
Name:	ImageUploadedByAirstream Forums1479856316.497712.jpg
Alumalarkey is offline   Reply With Quote
Old 11-22-2016, 04:18 PM   #2
dznf0g's Avatar
Oswego , Illinois
I got no real good response other than JB Weld and very careful reassembly.
-Rich-
Old 11-22-2016, 05:04 PM   #3
2014 30' FB FC Bunk
City , Maryland
So I looked at some pictures online and it looks like that's the end that connects to the drain cup. So the barb that broke is part of the molded cup.
Old 11-22-2016, 07:09 PM   #4
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I replaced mine with a brass barbed fitting and JB water weld. Drilled out pan where tube attached a replaced with brass fitting water weld putty around it and done
Old 11-23-2016, 06:24 AM   #5
dznf0g's Avatar
Oswego , Illinois
This is a good solution if you can easily get to the side of the cup.
-Rich-
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Broken or clogged A/C drain line danjoe91 General Repair Forum 5 05-13-2013 09:01 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
