Old 11-14-2015, 06:39 AM   #1
PSU1981
2015 27' Flying Cloud
Spring , Texas
AC Ducts Blowing out white dust
2015 Flying Cloud - when I turn on AC or heat pump white dust particles blow out. Any idea what this is? Is this usual?
Glenn
PSU1981 is offline   Reply With Quote
Old 11-14-2015, 07:08 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Sounds like little pieces of Styrofoam. Does the dust cloud stop after a few minutes, or does it continue as long as you run the unit?
Old 11-14-2015, 07:23 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Have you cleaned the return air filters? These are the rectangle ones on the ceiling. When used a lot these actually need to be cleaned about every two weeks. We have a 2015 FC and found this out while traveling this summer for about 8 weeks. Dust was everywhere, I pulled one off and it was actually almost clogged it was so dusty.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 11-14-2015, 07:26 AM   #4
PSU1981
Spring , Texas
Will try cleaning the return vents - thanks!!
Old 11-14-2015, 07:27 AM   #5
PSU1981
Spring , Texas
So how do I remove the return vent covers?
Old 11-14-2015, 08:22 AM   #6
paiceman's Avatar
I get my finger under one corner and pop it off by pulling down. They are held in place by three clips (if I remember correctly) and once started come off easily. We have one which does not come off easily so I take a towel put it under a flat nosed screwdriver and get the cover started that way and then use my fingers.
They pop right back on once cleaning is done. I also take a small shop vac and vacuum as far up inside the vent as I can.
Bud
SAFE TRAVELS
Bud
Old 11-14-2015, 09:22 AM   #7
PSU1981
Spring , Texas
Thanks!!
Old 11-14-2015, 09:36 AM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have a 2015 Flying Cloud 25FB with the ducted air conditioning system. We bought her new about thirteen months ago.
We have used this trailer quite a bit (18,000 miles/190 nights of camping). We have not experienced the whit dust situation that you describe.
I would definitely first try cleaning the a/c return filter. We have been doing this regularly. I try to vacuum the air return filters from the outside every week or so. I also remove the filter for a thorough cleaning every month or two.
Here is a photo of the vent and filter removed for cleaning.
Brian
SuEllyn & Brian McCabe
Old 11-14-2015, 11:48 AM   #9
2015 25' International
Rittman , Ohio
We have the same issue with a 2015 International Serenity 25FB. The white dust is only coming out of the ducts above the table. It started on our second trip with the trailer - and it occurs whether you're running the A/C or the heat pump. I pulled the filters after the second trip and they were clean.
I contacted the dealer and Jackson Center and both said they'd never heard of such a thing and told us to take it to an authorized repair center for Dometic.
Since it was early in the season and upper management didn't want to clean it out to take it to a service center, we opted to keep using it (it's under warranty) and buy a Milwaukee battery powered shop vac to clean up the dust while in use.
rabid54
Rabid54 is offline   Reply With Quote
Old 11-14-2015, 02:11 PM   #10
PSU1981
Spring , Texas
Cleaning out the duct filters seems to have worked - it also was just the vents above the table.
Old 11-14-2015, 04:11 PM   #11
amaier7771's Avatar
2013 25' FB Flying Cloud
Colorado Springs , Colorado
We had that white dust come out and cover everything overtime we used the air conditioner for the first two years. In frustration I finally took the entire interior air conditioning shroud and vacuumed it all out. It looked like stuff left over from when JC cut the hole for the air conditioner??? Looked like small pieces of white plastic or styrofoam? Also cleaned the filters, etc, and have not had any problem since.
amaier7771 is offline   Reply With Quote
White dust coming from vents in new '15 International ciparis Furnaces, Heaters, Fireplaces & Air Conditioning 7 09-17-2014 02:27 PM
Heat Ducts Dr Dan Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-10-2010 01:53 PM
Heat ducts Dr Dan Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-10-2010 01:43 PM
Furnace Ducts Chip Arnold Furnaces, Heaters, Fireplaces & Air Conditioning 9 11-26-2008 08:10 PM
furnace ducts?? 76argosy28ft Furnaces, Heaters, Fireplaces & Air Conditioning 15 01-11-2004 05:25 PM
