Old 10-15-2016, 03:17 PM   #1
2015 25' FB Flying Cloud
Georgetown , Texas
AC condensate tube on 2015 25' FB Flying Cloud
I cannot find the condensate tube on our 2015 Flying Cloud. The condensate is running off the roof. The only tube open to the outside is on the curbside, just aft of the small storage bin. Inside that bin is a white valve that releases water through that tube to the ground when turned. I have no idea where that water is coming from. The freshwater tank is empty. A condensate line wouldn't have a valve, would it?
GLovedahl is offline   Reply With Quote
Old 10-15-2016, 03:31 PM   #2
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
On our 19 Bambi, the condensation tube is located next to the streetside wheel well, a short dark stubby tube. This goes up to the AC but occasionally we get a few drips inside the coach. They are known to sometimes get block with something or other.
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 10-15-2016, 04:16 PM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
My 2013 25FB is like crazylev's 19: forward edge of street side wheel well.
The valve and drain tube by your water heater is for draining part of the interior plumbing.
SSquared is offline   Reply With Quote
Old 10-17-2016, 02:35 PM   #4
Georgetown , Texas
Finally found it (them) by using the sense of touch rather than vision. TWO of them up under the street-side wheel well, right where they're supposed to be. One question....I plan on using an air compressor to clear the lines....anything to watch out for? Thanks
Old 10-18-2016, 10:42 AM   #5
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
I had the same problem on my 2013 25FC. I removed the inside cover and found the drain lines routed over the power cord. I rerouted the tube and blew it out And works fine. I do not know you could do that in the ducted systems.
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 10-18-2016, 10:55 AM   #6
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Sounds like a warranty item. Take it back for diagnosis.
Kelvin
Old 10-18-2016, 12:39 PM   #7
2016 25' Flying Cloud
Friday Harbor , Washington
Be certain to tell what you discover. I have a 25FC, 2016 and might have to look into a similar issue.
Rob Cope is offline   Reply With Quote
Old 10-18-2016, 01:21 PM   #8
Weatherby Lake , Missouri
I have a 25FB FC as well
I have a FC 25FB 2016 as well. My trailer came with 50 amp service and two air conditioners. The condensate tubes for the AC units run down a 1/2 clear plastic tubes that terminates just forward of the front tire on the driver's side of the trailer. I don't know if Airstream runs a second 1/2 tube in case of a later addition of a second AC unit - rare but not unheard of. The two drains that you located sounds more like the low point drain valves for the hot and cold water lines. They are made of brass and have red paint on the end of the valves. I do open these low point valves and use the compressor to blow those lines dry as a part of the winterization process. However, these low point drains are completely isolated from the AC condensation discharge tubes (which don't blow out as a part of that process). You can access the tubes by removing the filter covers from the ducted returns in your trailer - mine can with a pinch in one of the tubes that resulted in poor drainage from the unit. A blockage in the AC condensate line could cause water to come off the roof as it overflows the drip pan. I hope that helps.
SemperBadger is offline   Reply With Quote
Old 10-19-2016, 10:48 AM   #9
Georgetown , Texas
I also have a 2015 25' FB Flying Cloud
Our condensate tube is streetside forward of the wheel well....it drips onto the streetside forward tire (black tube).
D2LLIO is offline   Reply With Quote
Old 10-20-2016, 04:47 PM   #10
2012 25' FB Flying Cloud
Georgetown , Texas
Our 2012 had the most of the water running off the roof, usually by the door. It turned out that the AC drain pan was cracked, which was fixed under warranty but took 3 trips before they figured that out.
barrettjl is offline   Reply With Quote
2015 GMC Yukon Denali 4WD & 2015 Flying Cloud 30 ? DHart Towing, Tow Vehicles & Hitches 22 04-09-2015 07:01 AM
A/C condensate drain tube? Gearheart All Argosy Trailers 3 07-02-2014 10:29 AM
AC Unit dripping condensate Rosie39j Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-19-2006 06:44 AM
Condensate Drain mkeith54 All Argosy Trailers 3 08-18-2003 02:01 PM
'70's condensate drain? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 12 04-16-2003 07:05 PM
