10-19-2015, 06:52 AM
2015 23' FB International
Vail
A mouse in the kitchen
Hi:
Any tips on figuring out how mice get in an how to keep them out? Can't see any obvious entry points under the Safari.
Thx,
10-19-2015, 07:40 AM
Curtis Wright
Eyren Haven
, South Jersey
They are mice. They get in. I think they walk through walls.
10-19-2015, 08:03 AM
Mission
I suspect when the steps are out in use, if you look there is a small opening into the underbelly - once there ...
10-19-2015, 08:14 AM
Sneedville
, Tennessee
We keep a couple of packets of Fresh Cab under the sink and in where the water pump is. Haven't had anymore mice come in so far.
10-19-2015, 08:32 AM
1974 Argosy 20
Kooskia
, Idaho
All the holes through the plywood floor where the drain and vent pipes penetrate are the usual suspects. Airstream cut big holes for little pipes and never sealed around them. Find all the holes, fill them with expanding foam or cut metal shields for them to keep the mice out. Also, the furnace has 2" ducts which go to the tanks for heating them. More holes, and the ends of the ducts are open, nice mouse runs.
That said, I have had many Airstreams, and some I never could find the mouse entry points.
10-19-2015, 09:42 AM
1967 22' Safari
MILAN
Are you sure it was a mouse?
Or could it be Rataouille! Sorry, I just couldn't resist! LOL! Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
10-19-2015, 09:46 AM
Oswego
Remember the movie, Fantastic Voyage? That's what mice do!
-Rich-
10-19-2015, 10:59 AM
1996 34' Excella
Elberta
, Alabama
Peppermint oil on cotton balls spead around the trailer should keep them out...
10-19-2015, 11:02 AM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
While you are working on getting it super sealed and figuring out where they are getting in. A straight sided bucket with water works also.
Hittenstiehl
10-19-2015, 11:19 AM
2002 23' Safari
Kalispell
, Montana
Check for holes in the rear bumper compartment and use foam and tin can lids to seal.
10-19-2015, 11:21 AM
2010 27' FB Flying Cloud
Magdalena
, New Mexico
We use the bucket/w water in our garage. Add a drop or two of dish washing liquid.
Charlene
10-19-2015, 11:26 AM
1962 28' Ambassador
Mesa
Bayou does the added dish soap make it slippery, or keep the floaters smelling good?
Hittenstiehl
10-19-2015, 12:07 PM
2002 25' Classic
Kalama
another way in
Some time ago I read a post here claiming that open frame rails under the tongue gave access. So I looked and sure enough, mine were open. Mesh and foam later, they have to look for another way in .
10-19-2015, 12:14 PM
Watertown
, Massachusetts
Bucket??
What does a bucket of water do, with or without the soap?
10-19-2015, 12:27 PM
1969 29' Ambassador
brooksville
Many people use dryer sheets. also take ALL of the Food out of the Trailer.
10-19-2015, 12:57 PM
1961 16' Bambi
1969 27' Overlander
Bonner Springs
, Kansas
Bounce Dryer Sheets
We use some of the same metods mentioned above and then put the original Bounce dryer sheets every where. This has worked for us so far.
10-19-2015, 01:27 PM
Yertle01.com
2006 22' International CCD
Estes Park
Plug every hole you can find, no matter how small, and then set traps inside anyway until you're convinced the problem is solved.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
10-19-2015, 01:28 PM
2012 23' FB International
Woodstock
, Ontario
YES!! Also the open ends of the Trailer A frame behind the hitch are entry points since the frame has holes cut into it back under the floor. I had mice one year ,but not before that. I had left the chains dangling and touching the ground....mice. Pulled the chains up ...no mice. Some owners stuff the open ends with bronze wool or large bronze or stainless scrubbies.
Mothballs under the trailer in a closed space work well to deter mice.
My experience...no food...no mice
JCW
10-19-2015, 01:45 PM
1962 28' Ambassador
Mesa
WARNING DON'T READ IF YOU LIKE MICE.
Sallye,
They want to drink and once in the bucket they can't climb out. Eventually drowning.
We are not intentionally cruel to any critters but won't have snakes, bugs, scorpions or mice/rats in yard, house or trailer.
Hittenstiehl
10-19-2015, 05:30 PM
2013 31' Classic
billings
, Montana
That's right, no food also dog food in the trailer no mice, ask how I know !!
