Old 06-15-2008, 04:16 PM   #1
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
Question A Good Floor Jack
I was hoping for some suggestions regarding a decent floor jack, to be used mainly with my trailers...and maybe my F150 on the rare occasion that I might actually attempt to perform something mechanical on it. I'm not near any of my trailers, so I can only guess at how much lift I might need to get the rubber on one side slightly off the ground. I'm thinking that 14" max might not be enough, and that maybe closer to 20" of lift would be a wiser choice...but I'm just guessing. The F150 has 17" wheels. I'm also assuming that a 2 1/2 ton capacity will be sufficient. I would prefer a unit that's somewhat portable and not too heavy (I consider 45-50lbs heavy). Also, as far as wear and tear is concerned, it won't get used all that often...I hope.
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 06-15-2008, 04:44 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I find that a jack from SEARS or NAPA usually fits the bill. I wear mine out about every 5-7 years even with annual fluid changes. 3-ton is the minimum for me nowadays.
slowmover is online now   Reply With Quote
Old 06-15-2008, 04:53 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
We have a Craftsman Professional 8 ton bottle jack I got from Sears for both the trailer and truck. I made a bracket that fits on top of the jack so the trailer won't slip off the small round top. It takes up much less room than a floor jack, especially a floor jack big enough to be useful for the truck and trailer.
Old 06-16-2008, 02:42 PM   #4
wlj1943's Avatar
1970 18' Caravel
Mulino , Oregon
Hi Rfield54,
I too use a bottle jack for travelling, and take 3/4" plywood 10X10 squares to use for a base on soft ground. I use a 10 ton professional Blackhawk that is over 30 years old and has been rebuilt once. I also fabricated an adaptor probably similiar to the one Overland made to prevent slippage out of a pipe stub welded to a 4X4 X1/4" steel plate.
A good floor jack is ideal for shop work, but I recommend at least a four or better 5 ton professional jack for Airstreams; very spendy but will last a long, long time. Good brands available from the major franchise auto parts stores (NAPA, Etc), and the tool trucks (Mac, Snap-on) and professional tool and shop suppliers. Stay away from most of the mail order, big box and imported tool "chrap" stuff. My jacks in our shop are all major brand professional units (including an older Craftsman professional unit) very heavy but very stable and ecomomically repaired. Hope this helps!
WLJ1943
wlj1943 is offline   Reply With Quote
Old 08-15-2008, 08:34 AM   #5
bookman's Avatar
1972 Argosy 20
youngstown , Ohio
you mean my $13 3 ton RV jack wasn't a good buy???? I've had it for two years and it works fine!
bookman is offline   Reply With Quote
Old 08-15-2008, 04:52 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
2-Ton Floor Jack - Jacks & Stands - In Your Garage - Griot's Garage
3-Ton Wide-Saddle Bottle Jack - Jacks & Stands - In Your Garage - Griot's Garage
Already have a floor jack left over from my knuckle busting days.
Have purchased some very nice stuff here, these look interesting.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-15-2008, 07:14 PM   #7
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
you mean my $13 3 ton RV jack wasn't a good buy???? I've had it for two years and it works fine![/quote]
Well, you're the one laying under it!!
SafariSS is offline   Reply With Quote
Old 08-15-2008, 07:44 PM   #8
Mexray's Avatar
1978 28' Ambassador
Morada , California
Sorry...couldn't resist...
When I 'use' too much 'Jack', I usually end up laying on the 'Floor'.....
Ray & Pat; Morada, CA
Looking for a floor jack recommendation Globie64 Mechanics Corner - Engines, Transmission & More... 4 02-13-2008 05:46 PM
Should I trash my Sears floor jack? Kistler Our Community 35 08-05-2007 06:28 PM
How do I jack up my AS?? (Thanks!!) fugarwe Jacks, Stabilizers, Lifting and Leveling 5 03-29-2007 05:24 PM
Jack for my new AS Double D Jacks, Stabilizers, Lifting and Leveling 11 04-06-2006 08:09 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
