Old 08-04-2008, 09:03 AM   #1
2004 19' Bambi
Denver , Colorado
Images: 32
A Couple of Minor Repair / Maintenance Questions
Hi all,
I have a 2004 19' Bambi with a couple of minor repair / maintenance items that I need to address.
#1 I noticed when I was washing it yesterday that the putty around the tank vent on the roof has dried and started to crack. I'm not seeing any indication of any interior leaks thus far but would like to seal that back up. Can anyone tell me what type of putty to use and should I attempt to remove the old putty before applying new?
#2 The sliding privacy screen that separates the bed from the galley has a broken hang tab on the leading end that attaches to the cabinetry when closed. Is there a way to replace this tab or do I need to replace the whole leading end or, worse yet, the whole screen?
Thanks in advance for any info.
-Kevin
COLORADO_CAMPER is offline   Reply With Quote
Old 08-04-2008, 09:31 AM   #2
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Kevin,
Thoughts on #2- We have the same problem on our 19. The (cheap) plastic tab that holds the leading end of the screen in the upper track has become mis-shaped and rarely stays in place after popping it back in, especially after travel.
Since we have never really use the screen and never had "guests" that we needed to wall off, I'm actually thinking of completely removing the screen. When folded, it projects out about four or five inches, and to us it's also dead weight. If we want privacy, we close the blinds. Removing it might give the illusion of slightly more room.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 08-05-2008, 03:49 PM   #3
2004 19' Bambi
Denver , Colorado
Images: 32
Originally Posted by crazylev View Post
Kevin,
Jonathan
Yeah, unfortunately we use the screen quite a bit so removing it isn't an option for me.
Does anyone know if this part (or the whole screen) can be ordered - maybe directly from the manufacturer?
-Kevin
About to take the plunge, a couple questions first. WhiskeyRiver General Repair Forum 3 10-09-2007 04:08 PM
Newbie has a couple questions: MG911 Buyer Guidelines 46 08-05-2007 04:58 PM
various shorts solved, few minor questions richard77 Electrical - Systems, Generators, Batteries & Solar 4 10-04-2006 07:59 PM
A Couple More Questions slow-canoe Argosy Motorhomes 7 03-06-2006 04:47 PM
Couple questions kl8ton 1970 - 1973 Sovereign 5 06-13-2005 09:05 AM
