Old 03-14-2016, 06:43 PM   #1
2015 27' FB International
Des Allemands , Louisiana
A/C Drain Tube
Have a question we hope someone can help with. We cranked up our dual A/C units today to check them out and noticed that only one of the two drain tubes by the wheel well is dripping. The other one is completely dry. Has anyone experienced this? If it is clogged, what is the best way to unclog the tube? Thanks in advance. If it helps, this is a 2015 27FB Serenity.
AraExpress is offline   Reply With Quote
Old 03-14-2016, 10:34 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Perhaps bugs... not the ones we eat... but Mud Daubers... a blight ... yes.. bugs do nest in the Acs.. I have found wasp nests whenever I pull the covers. There is probably enough moisture in the air in Des Allemands...so, leave doors and windows open.. run AC on full. Use a screwdriver to clear the opening of the tube... if no water, then use a shop vac to pull the water thru... use a rag covering the hose just enough to seal the condensate line... then switch on the vac... do you get any gunk out? The rag should tell you by what it catches..
Now, on our 1999 enough nests were in there that they clogged the old condensate drains inside the AC.. had to pull and flush it.. but it had a plastic pan between the AC and the roof.. have upgraded to proper drains.. but that shouldn't be your problem..
Also.. I forgot.. which way is the AS leaning??? might take more condensate to get the flow going..
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-15-2016, 08:23 AM   #3
Thank you CWF!
Going to try the above! Thanks for the tip to use the shop vac!! Will report back.
Old 03-15-2016, 08:31 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Are you sure it is attached to the AC?
MICHAEL
How do I clean my AC drain tube? tyndalelady Furnaces, Heaters, Fireplaces & Air Conditioning 67 05-13-2013 11:55 AM
Rubber drain tube near H2O hookup - what is it? mendosoft All Argosy Trailers 13 07-17-2008 08:27 PM
Coleman TSR Mach 3 Drain tube bertro Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-07-2008 10:57 AM
drain tube for ac ?? PeteL Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-26-2008 09:26 AM
AC condensation drain tube IndyAnne 1959-69 Tradewind 10 04-10-2008 03:05 PM
