Old 10-06-2017, 10:56 AM   #1
1999 30' Excella 1000
Maryville , Tennessee
'99 Excella 30' Water Heater Bypass Valve Access
Hello everyone!
The water heater bypass valve (the one in the horizontal part of the "H" valve configuration) has a slight drip coming from the valve stem. Normally you can tighten the packing nut and fix this, or remove the packing nut and replace the packing/gasket with a rebuilt kit. They're basically toilet/sink valves.
Anyway, I can barely get to the valve (through the undersink cabinet door) to turn it on or off. I don't really see a possibility of getting two wrenches in there (one to hold the valve and the other to tighten/remove the packing but). Am I missing something? I'd like to eventually replace these multi-turn valves with quarter turn ball valves, but I really don't see a way to get in there and cut the pex bands or wield a pex band crimper.
Thanks for any advice.
disneyd is offline   Reply With Quote
Old 10-06-2017, 11:07 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Same setup in my Classic 30. The simplest (only?) solution may be to disconnect the gas line and water lines at a convenient place and pull the heater.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-06-2017, 11:12 AM   #3
Al
Do you disassemble the cabinet to pull the heater or does it come out through the bottom or side of the trailer?
Old 10-06-2017, 11:27 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Mine was weeping. I temporarially gave the shaft a shot of silicone lube 5 years ago until I could get around to it....
Still dry 5 years later.
Old 10-06-2017, 12:04 PM   #5
2000 30' Excella
Toledo , Ohio
Good luck with that I can barely get my hand in there to turn the valve . Thinking about cutting some kind of access door in the cabinet but haven't done it yet . Other thing would be to remove the entire cabinet that wouldn't be fun either . So far no leak .
woodfox45 is offline   Reply With Quote
Old 10-07-2017, 09:41 AM   #6
HankO's Avatar
1997 28' Excella
Eden , Utah
Access to heater bypass
I don't know what type of configuration you have in your bedroom but in my 97 28' Excella I gained access by lifting up the platform of one of the twin beds on heater side and holding it up with a piece of 2x4.
Hope this helps,
Hank
HankO is offline   Reply With Quote
Old 10-07-2017, 10:04 AM   #7
Mine comes out through the side of the trailer where the door is.
Al
S/OS #004
Old 10-07-2017, 10:29 AM   #8
USN Mustang's Avatar
1997 30' Excella
Virginia Beach , Virginia
I have a 30' 97 Excella Classic. It sounds like the bypass valve is located where mine is. I had to get into that same area to fix a leak in a split line and had to take out the sink/cabinet to do any effective work. Its not hard, just a little cumbersome trying to move the cabinet away from the wall. I did have to ease the bedroom bulkhead alittle to bring it out though.
USN Mustang is offline   Reply With Quote
Old 10-09-2017, 10:35 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Should be in another little door inside the bathroom cabinet under the sink.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Hot Water Heater Bypass Valve Access donreitz 2009-2015 Flying Cloud 2 03-17-2018 06:25 PM
Wintertzing Question In Summer: Bypass Valve Access donreitz Winterizing, Storage, Carports & Covers 9 07-28-2017 12:32 PM
Location: Water heater bypass valve? Will_Brule Water Heaters, Filters & Pumps 16 11-10-2014 05:44 PM
Water heater bypass valve Robfike General Motorhome Topics 6 05-11-2014 06:21 PM
Water Heater Bypass Access davidz71 Water Heaters, Filters & Pumps 1 07-06-2007 10:18 PM
