Old 03-03-2012, 08:46 PM   #1
82 excella's Avatar
1984 34' Excella
'82 excella main zip dee awning will not open
Please if someone knows how to open an 82 zip dee awning please help, mine seems to be stuck on the roof will not move, the round screw downs were rusted so I had to drill them out but still will not lift off the roof and unroll?
82 excella is offline   Reply With Quote
Old 03-03-2012, 09:06 PM   #2
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
I have a 94 excella. My zip dee has a lever on the right side of the awning where the right support arm connects to the main awning tube. The lever has a round hole in the end. You use the rod to insert into the hole and pull the lever out. The lever releases the awning so it can unwind. I also have two tension wheels, one left and one right, that have to be unscrewed and toggled away in order for the awning to be pulled out.
Tac GA-20
Air Forums 20320
KeithC is offline   Reply With Quote
Old 03-03-2012, 09:07 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
You may find some hints in this thread. I had a 75 Sovereign that had a stuck awning, also.
Zep
Sneakinup will do great things with this Sovereign TomW 1974 - 1979 Sovereign 38 09-14-2015 03:59 PM
I was told 'Not to Join'??? Travel Bird WBCCI Forum 159 05-09-2015 05:46 AM
Shock absorbers on my 1989 Excella 29 RBosque Shocks 14 03-05-2012 12:31 PM
Factory tongue lift will not come out. Hopichangi Hitches, Couplers & Balls 6 03-05-2012 12:00 PM
'82 excella main zip dee awning will not open 82 excella General Repair Forum 2 03-03-2012 09:07 PM
