Old 10-10-2019, 06:57 AM   #1
1962 22' Safari
Virginia beach , Virginia
81 Excella ll, 31' brakes
I'm considering purchase of 31' 1981 excella ll trailer with an antiquated brake system. On the tongue there is an old brake booster with a master cylinder..will try to attach picture. I am curious if the system can be converted to all electric? And if so is it a major undertaking with high cost? Thanks to any and all who may have advice!
Project81 is offline   Reply With Quote
Old 10-10-2019, 08:06 AM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
The cheapest and easiest way to go would be an electric brake system which will require new packed backing plates, drums, bearings and associated 12ga. wiring.
If your planning on any amount of extensive traveling and your starting from scratch I would consider a few more dollars and go to a modern disk brake system. Both are DIY projects if your handy in mechanical work.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old Yesterday, 05:57 AM   #3
1962 22' Safari
Thank you for the information. Disc brakes for a little more money would be wise. If i were to DIY what source do you recommend for the parts?
Old Yesterday, 03:51 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Project81,
You will need a electric over hydraulic actuator ($500+) and possile new calipers and discs. If you go with Kodiak discs the old Airstream aluminum wheels will not fit and you will also need new wheels. I don't know about the wheel fit on Dexter discs. Having said that, I believe that disc brakes are much better, I have them on both of my trailers.
Bill
Just my personal opinion
Old Yesterday, 05:16 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I put Kodiak disc brakes on my Classic 30. The stopping power is amazing! My original 12" electric brakes just weren't providing sufficient stopping power. You may be able to replace your actuator with a modern one and re-use the exiting lines and calipers. That would be about the same price as new electric brakes all around.
http://www.airforums.com/forums/f439...ss-177345.html
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Can the drum brakes be changed to disc brakes? MOS Brakes & Brake Controllers 51 11-15-2018 04:05 PM
Emergency flashers apply brakes and ID brakes detree Brakes & Brake Controllers 12 01-23-2010 09:16 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 09:18 AM
