Old 09-03-2016, 11:13 AM   #1
Indian Trail , North Carolina
79 Airstream Soverign low voltage lighting problem
I have a 79 Land Yacht Soverign. I am having problems with the overhead kitchen light, galley light, step and flood lights .
I have recently installed a new Boondocker transformer but it did not solve the issue. All the fuses look good and I installed all new bulbs. I have also checked the breakers.
Can anyone help me ?
Airdana is offline   Reply With Quote
Old 09-03-2016, 12:32 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have glass fuses, one could appear good but is not. Make sure they are tight in the holder. If you know how to use a multimeter you can check for voltage on the "load" side of the fuse when you have a switch turned on for one of the fixtures you are having a problem with. If you read 12 volts on one side of the fuse and not the other then the fuse is bad.
Airstream Soverign 31 SAirstream Soverign 31 eBay Watch Airstreams on eBay 0 09-08-2011 10:00 AM
Weird low voltage problem hhendrix Electrical - Systems, Generators, Batteries & Solar 6 09-01-2011 09:20 AM
how low is too low AC voltage? WineStream Electrical - Systems, Generators, Batteries & Solar 59 12-18-2009 02:56 PM
Low voltage... converter or battery problem? patrickdylan Batteries, Univolts, Converters & Inverters 5 08-22-2009 09:24 PM
Low Voltage Problem kellyw Electrical - Systems, Generators, Batteries & Solar 3 10-23-2002 06:35 PM
