Old 12-27-2014, 09:30 AM   #1
freon's Avatar
1977 23' Safari
Houston , Texas
'77 Safari
Dear Streamers,
This is Freon, I am new to this site and Airstreams! I recently bought a '77 Safari and am trying to put it back together as the PO dis-assembled the entire interior. After 7 or so hours of searching on this site for R&R info on the bath and black tank I am now asking you forum pros if you can help me find a thread with pictures or refer me to a member on this site that can show me what parts need to be in place. I have the black tank in place with a cut out for the dump plumbing, a plywood spacer and the plastic molded tank cover in place. The problem is that it is sitting an inch
below the original rivet holes in the rear shell wall. Also I would like to know how the supply water plumbing was routed. Hopefully someone with a '77 Safari twin has done this and knows the answer! Merry Christmas to all!
Freon
freon is offline   Reply With Quote
Old 12-27-2014, 10:02 AM   #2
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Try these links and maybe they will help answer some questions for you;
Document Archive - Airstream
http://www.airstream.com/wp-content/...0c7613c742.pdf
and then here are some actual pics, just look up by year/model;
Vintage Airstream Photo Archives - Vintage Airstream
good luck
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 12-28-2014, 12:55 PM   #3
freon's Avatar
1977 23' Safari
Houston , Texas
Thanks Steve! really appreciate it!
And your doing a really great job on the '58 Traveler!
freon
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
22 safari sport vs. 20 safari jeffrho Member Introductions 10 01-04-2008 07:52 PM
Safari 19' vs Safari 22' michael165 2006 Safari 15 06-04-2007 06:02 AM
On a safari for our Safari 3DogNight 2007 Safari SE 10 12-21-2006 12:54 AM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
