Old 05-31-2013, 12:26 PM   #1
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
Question '77 IS 31' pump up tongue jack
Can anyone identify the pump up / release down hydraulic tongue jack? Would like to restore / rebuild it as to replacing it. Hopefully will have more lift inches. Can not find any names or other info on jack. There has to be a way to access its workings. There is a round 12 handle that is used to pump the tongue up. The valve in the upper area is opened to release the fluid and lower the tongue. In advance, I thank any and all contributors. JC
Jim & Mitzi is offline   Reply With Quote
Old 05-31-2013, 12:56 PM   #2
1974 Argosy 20
Kooskia , Idaho
Ah, memory lane. I had one of those on my very first Airstream, a '70 21' (or was it 23'). At any rate, it died and as I recall, even back in the late 70's when I had it it could not be repaired. Now, this was long ago, and maybe I am wrong, but you may not be able to find much help on them now.
Old 05-31-2013, 01:13 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I had never seen or heard of such a thing... but wouldn't you know it, you can still get a hydraulic tongue jack.
I guess it might be good for an environment where you want easier action than a hand crank but don't want to rely on an electric system, but it seems to cost more than some electric ones!
— David
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Electric tongue Jack vroom Hitches, Couplers & Balls 3 12-02-2011 11:45 AM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
Tongue jack lowers/ Does not raise Lumatic Electrical - Systems, Generators, Batteries & Solar 3 10-10-2011 09:53 PM
Need Tongue Jack - Suggestions? kj78133 Jacks, Stabilizers, Lifting and Leveling 16 02-23-2011 05:55 PM
