Old 05-17-2014, 10:16 AM   #1
Okiestreamer's Avatar
1999 25' Safari
Adair , Oklahoma
'74 Sovereign Roof Vent Question
We are planning on replacing two of our roof vents in our 74 31' Sovereign with Fantistic vents. All these vents have been replaced over the years and the one in the bath has a 12 volt motor to power the fan so power is there for a new Fantastic Vent.
The vents in the front do not have motors so no electric power appears to be available. Here's the question? Did one or both of the vents in the front have electric powered vents when it was manufactured? If so, power may be there that we can use but is capped off. We would appreciate input from those of you that have encountered this situation.
Dave
Okiestreamer is offline   Reply With Quote
Old 05-17-2014, 11:35 AM   #2
All of the vents have a 12 volt supply, but when a motor is not used, the wire is hidden in the ceiling at the vent.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-17-2014, 12:10 PM   #3
1974 Argosy 20
Kooskia , Idaho
Since the 12 volt power wires for virtually everything run down the center of the roof you can probably find a hot line nearby when you pull the roof vents you have out. I think 2 of the 3 roof vents had a power fan in them originally, but I am not sure about that. At any rate, I think you will be able to find power close when you get the old vents out.
Old 05-17-2014, 09:24 PM   #4
1999 25' Safari
Adair , Oklahoma
Thanks Andy and idroba! Just the info I needed.
Dave
Old 07-17-2020, 09:28 PM   #5
1977 31' Sovereign
Warman , SK
Three vents in my 77 sovereign.
Should I replace all three with power vents?
Fan-Tastic or Maxxair?
Blockparty is offline   Reply With Quote
sovereign
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
Wires/Power for stove vent & roof vent. Jeepers! 1956 - 1965 Caravel 3 10-03-2014 09:21 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Hehr roof vent question pgajkowski Roof Vents, Skylights & Fans 1 06-06-2005 08:25 AM
