Old 05-03-2012, 09:12 AM   #1
1972 23' Safari
Prineville , Oregon
'72 Safari windows/accordian style cupboard doors/caulking roof vents
I have recently acquired a 72 Safari. I am the third owner and as it has sat unused for several yours (10 or more) it is needing some TLC. I would like to replace the exterior window seals. Also the roof vents are in need of recaulking, but I'm not sure how to get up there to do the job. Will an A/S roof support the weight of a 200 lb man? This A/S has the accordian style cupboard doors...some of which are broken. Are replacements available or can they be adapted to a different style door? Thanks for help...its great to have a place to go to with so many questions.
gconn is offline   Reply With Quote
Old 05-03-2012, 06:47 PM   #2
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
hello and welcome!
Hi,
Yes the seals for windows are available, look into Inland RV, Out of doors mart, and others to find them. I like/have had good service with Inland. Re-caulking is a necessary job on these trailers. I use a good tall wooden ladder and can rear the center. I usuallly have someone holding the ladder if I am stretched out over the roof. They say you can walk on the roof ALWAYS stay on the rivet lines, and NEVER on the endcaps. I myself cannot bring myself to try it. I have had very good luck repairing the tamboor doors. New material is available, not a perfect match (some of my doors had been done by PO)and it's not cheap. I used carpet seaming tape, the kind you heat with an iron. I removed one door at a time keeping the door in proper stacking order, and used 4 strips of seam seal almost to the ends, and two in the middle. I am pleased to say that so far they are working pefectly. OK, now the best part, we love pics, so can you share some with us? You reallly want to take them to document progress antway. Cheers, John
moparjohn is offline   Reply With Quote
Old 05-04-2012, 07:26 AM   #3
1972 23' Safari
Prineville , Oregon
Thanks so much for the info. Greatly appreciated. Yes, I'll be taking some photos...always fun to see what others are doing.
