Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 12-16-2016, 09:24 AM   #1
1972 23' Safari
Middletown , Rhode Island
72 Safari bathroom removal
Hi I'm about to remove my bathroom to fix a rotted floor and rusted rear frame. Any tips before I start? Is it pretty easy and self explanatory. Drill out rivets cut old sealant caulk away? I want to keep the bathroom original so will be using everything I take out again. Any help/suggestions appreciated.
Mx468 is offline   Reply With Quote
Old 12-16-2016, 09:32 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There will be rivets hidden by trim pieces, etc.. Be very gentle, as that old ABS plastic will want to crack at any chance. Take pictures as you disassemble so that you can see how it went together when it is time to reassemble. The drain in the tub/shower will likely be frozen and you will have to saw off the drain pipe from underneath in order to get the shower pan out.
Good luck!
Rivet Removal Tool OR Blind Rivet Removal T mkamanu General Interior Topics 3 10-12-2015 07:29 PM
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
Bathroom Removal Keyholeren Cabinets, Counter Tops & Furnishings 6 11-06-2004 07:12 AM
bathroom compartment - removal? Cruiser General Interior Topics 7 05-16-2003 07:24 PM
