Old 07-22-2013, 05:14 AM   #1
'71 Air conditioner problem
The original Armstrong air conditioner on our 23 foot Safari cools good for about an hour. Then it trips a breaker and quits. Any ideas what causes this and how to fix it?
Dan
Dbraw is offline   Reply With Quote
Old 07-22-2013, 05:55 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Could be several things. I'd look a the breaker first. They do go bad. I would swap the AC breaker with another of the same rating and try that first. I have a good friend with a 67 Overlander who had the same issue recently and it was the breaker. If that doesn't fix the problem, then you will need to get the ladder out and head to the AC. There are many threads here on the forums that you can research on checking the start and run capacitors and the relays. Since it is working for a while, hopefully the problem is just a simple (and relatively inexpensive) electrical component.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is online now   Reply With Quote
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Air conditioner went south... Bing-Bing Furnaces, Heaters, Fireplaces & Air Conditioning 12 06-16-2011 06:14 PM
Air suspension connection warrenivan General Motorhome Topics 4 06-09-2011 03:43 PM
Old air conditioner removed... Steps for new installation Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2011 03:25 AM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
