Old 03-05-2016, 08:59 PM   #15
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I think I still have the original vents that I took out of my '74 Overlander if you're interested in keeping them original. I replaced them with Fantastic Fans. In the second post to the thread linked here there is information on an alternative way to upgrade the original vents using a radiator fan.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is online now   Reply With Quote
Old 03-05-2016, 09:44 PM   #16
1977 31' Sovereign
Lynnwood , Washington
Airstream part number: 092 1105 roof vent cap.
Price = $38 in 2001
Vent opening on roof = 13 3/4" (outside dimension)
plastic cap = 14 1/8" (inside dimension)
Dimensions are pretty close. I measured from inside. Difficult to measure.
This entire cap is plastic. I replaced mine in 2001. No problems ever since.
These caps are Airstream and are universal "blanks." You hafta drill your own holes and supply your own rivets. I used garden variety rivets and good quality silicone sealant.
I hope this helps.
Tom
TomKirk is offline   Reply With Quote
Old 03-05-2016, 11:00 PM   #17
1977 31' Excella 500
Dallas , Texas
I'm following that model. One thing. I believe we should prefer poly caulk to silicone on our metals. While most silicone now has latex in it, that's the only way it is acceptable to metal. Read the 100% silicone application. No metal. It still works. Poly is preferred.
Jack Moore is offline   Reply With Quote
Change a metal roof vent by a transparent roof vent ? GaŽl Roof Vents, Skylights & Fans 11 12-27-2014 05:55 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
