Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 12-03-2007, 06:52 AM   #1
Profile:  1968 26' Overlander
Ann Arbor , Michigan
Images: 11
68 Overlander ... Gutting
Well...I started gutting the overlander...with a mask on.
the carpet was breaking apart in my hand .
So... I guess the biggest part done.
I removed the goucho...(Nasty)
Removed beds (Nasty)
Removed all walls... (tricky)
Now trying to remove bathroom without destroying...(dont know what it is worth...its all plastic.)...Question...is this even worth trying to save or can I take a sawzall to it?
How do I remove the Toilet...I am not keeping it...It looks funny...it has two foot thingys on it for flushing.
Removed Stove
Removed Refer.
Removing bathroom is my only issue now.
Also...Leaking.
Leaking at the very front two side windows...how do I fix this?
Also leaking somewhere along the sides...floor rot behind the axels.
I figured I may need to take all the interior skin the panels out to get at the old wirig and insulation to redo. and I need to stop the leaks before doing a shell on floor replacement.
I think the only thing I am going to keep is the kitchen sink.
I also kept one of the big walls undamaged so I can use that as a template.
What are your thoughts.
Aluminati is offline   Reply With Quote
Old 12-03-2007, 07:40 AM   #2
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Airstream Registry
To remove the toilet there are two nuts that hold the toilet to the tank adapter and they are accessable from the back of the toilet.
Sounds like you are at the start of a big adventure
Old 12-03-2007, 08:14 AM   #3
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
The very first thing to do, if your trailer is not under a roof, out of the weather, is to find and re-seal all exterior leak points. If you search this forum, you'll find info on that- how to find leaks, the usual suspects, what sealant to use, etc. Without doing this first, you are peeing into a headwind. Good luck, and have fun!!
tphan is offline   Reply With Quote
Old 12-03-2007, 08:51 AM   #4
Darol Ingalls's Avatar
Profile:
Be sure you have a plan for replacing any of the bathroom panels, vanity, sink, etc. BEFORE you saw up the original. Finding replacements is nearly impossible and, due to the curves in that area, fabricating new parts is a real pain. Some parts are fiberglass and some are ABS vacuum formed parts. All can be repaired with epoxy and glass cloth applied to the back sides. Epoxy appliance paint (almond color) works good for repainting. Takes a good week of warm weather to set up properly and you need to be careful not to use harsh cleaning materials, but it's easier than new gel-coat or powder coating. Just don't get in the "toss it" mode before you know what you're going to replace it with! Darol
Darol Ingalls is offline   Reply With Quote
Old 12-03-2007, 10:08 AM   #5
Radman's Avatar
Monterey Bay , California
Images: 107
Alum,
I totally agree with all the other great advice you have been given. Keep everything that has an angle or curve to it. Patterns and guides to how it was done before your teardown are essential. As time passes you will forget how things actually were put together. It saves you from having to reinvent the wheel. Even if you won't be reusing some items. Wait until you rebuild those components before throwing anything away. You will see how valuable these things are as your journey continues. Good luck.
Radman is offline   Reply With Quote
Old 12-03-2007, 10:22 AM   #6
Images: 11
Not gonna use it
Well I have no use for the bathroom stuff... I am gutting the trailer out to make a mobile kitchen...so I wont need a bathroom. I have been very careful so far...I have not broken or chipped anything...The only thing I took of so far was the bathroom vanity. everything else is still in good shape. Yes you are correct...the tub part is fiberglass...but I wont need that...the bathroom sink or the toilet or tub I wont need.
Old 12-03-2007, 12:05 PM   #7
Profile:
Sure wish I lived closer to you. Could use all those bathroom parts. Too far and bulky to ship. What a waste! Darol
Old 12-03-2007, 12:49 PM   #8
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
No toilet...??? Believe health codes will require one and a sink - other than the kitchen area sink to wash your hands won't they...
GARY
OHIO - WE ARE THE MOTHER SHIP
Charter Member - NOVA
WBCCI - 5308
Ganglin is online now   Reply With Quote
gutting vintage airstream jean kosloff General Repair Forum 5 11-01-2007 03:38 PM
Gutting the Tradewind... sequoiacoast General Repair Forum 3 01-25-2006 11:22 AM
gutting interior feeling helpless Ed Starman General Interior Topics 37 04-04-2005 09:39 AM
Interior gutting advice? pinkflamingoes General Interior Topics 10 07-10-2004 11:27 AM
Gone in 60 seconds (gutting the interior) whistler Interior Restoration Forum 4 02-22-2004 06:17 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
