Old 04-25-2016, 08:32 PM   #57
1968 26' Overlander
Manheim , Pennsylvania
Subflooring progress!
I spent the afternoon leveling out the frame as best I could on my neighbors gravel "parking lot" (very thankful to him for letting me park her there, I even have a nice big tree for shade from the sun) my frame tends to want to twist a little I have noticed. But I managed to flatten it out with some blocks and shims. Then I started cutting up some AdvanTech! 88" wide across with a 6" board of their 1/2 "zip board" for the joint areas between boards where they recessed the frame. Retraced the back curve with the old c-channel and it was an easy cut with the jig saw... Tomorrow I hope to finish up and find some elevator bolts locally that won't break my bank. The big blue box has them at $1.05 each!? Yikes. I saw vintage trailer supply has a box of 50 for $15, so after shipping that is still half the price! Either way, it's nice to see some curves on her again! Click image for larger version
SonOfAnder
'68 Overlander
http://www.airforums.com/forums/f44/...te-145553.html
SonOfAnder is offline   Reply With Quote
Old 04-26-2016, 09:08 AM   #58
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Looking great! That's exactly how I did the curves on mine. When I made the 1.5 inch metal tube curve I used the same template also. Click image for larger version
Name:	ImageUploadedByAirstream Forums1461683160.821229.jpg
Fastenal has elevator bolts. They would have had to order the zinc plated so I just got the plain and painted with por-15. The price was about the same as vts.
Matt
rugjenkins is offline   Reply With Quote
Old 05-09-2016, 08:23 PM   #59
1968 26' Overlander
Subfloor is cut to size
The pup is claiming her spot on the brand new subfloor! I actually took this picture almost two weeks ago, but then it started to rain... And it didn't stop for over a week! I did cover the AdvanTech with a tarp just because I had my doubts, but to be honest, the scraps that were in the driveway didn't even swell. I'm pretty sold on this stuff... I did paint the edges with a coat of KILLs oil based primer since I cut most of the factory finish off. Not sure it was necessary but it looks cool! Hoping to finish fastenning everything down over the next few evenings and start on the C-channel. Then, to flip the frame or not flip the frame Click image for larger version
SonOfAnder
'68 Overlander
Old 05-11-2016, 11:14 PM   #60
Unka Jack's Avatar
Fonthill , Ontario
I flipped with the gantries. Never regretted the decision. Made life so much easier not having to work upside down plus gravity makes a great assistant.
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
Unka Jack is offline   Reply With Quote
Old 05-17-2016, 07:58 PM   #61
1968 26' Overlander
Buck Rivets!
It was like an early Birthday Present today on my doorstep! Aircraft Tool Supply has a very easy to navigate website with a full selection of everything I need to do some buck riveting. 3x Rivet Gun kit, 50 gold and 50 black Clecos, pliers, and lots of 4-5 and 5-5 AD rivets! They even sent me a free T-shirt (though it is a 2XL and I wear a Medium!) Really looking forward to laying down the new C-channel, re-attaching the banana wraps, and bucking the shell back down onto the frame!
SonOfAnder
'68 Overlander
Old 06-09-2016, 08:48 PM   #62
1968 26' Overlander
Corner C-channels
I have to give credit to HiHoAgRV for this one... I struggled with how to rebuild the bent up, broken, and reriveted curves of C-channel. I talked to a few sheet metal workers, and they simply said no way. Another company quoted me $800 for the four corners bent from extruded channel. To put it simple, there is no easy way to "bend" a channel without breaking it. Then I ran across his post and it made perfect sense. I had two pieces of angle bent out of .0500 aluminum so it has some strength, cut it on 2" increments for the inside curve and notched the outside curve so it could flex in without overlapping. Then I flipped my old existing channel upside down, copied the width at the middle with the two angles, cleco'd it fast, and simply worked the curve one section at a time. After all of the holes where drilled, I removed all the Clecos, removed all the burrs from the new channel, reinserted the Clecos from the bottom of the new curve and riveted it fast... It took a bit of time, but well worth it!
SonOfAnder
'68 Overlander
Old 06-09-2016, 08:53 PM   #63
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
That last photo looks like a good candidate for June's Photo contest!
duncans is offline   Reply With Quote
Overlander Land Yacht International :: 1964 Airstream Overlander Land Yacht Internati overlander64 Airstream Registry Discussions 2 01-27-2018 06:28 AM
Land Yacht Overlander :: 1968 Airstream Overlander Von Moritz Airstream Registry Discussions 0 10-10-2013 08:29 AM
The Overlander :: 1964 Airstream Overlander Janet H Airstream Registry Discussions 2 07-14-2013 03:04 PM
Overlander International :: 1973 Airstream Overlander rmoores Airstream Registry Discussions 0 01-31-2012 10:46 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
