Old 04-22-2013, 08:44 PM   #1
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
'67 30' Airstream, mystery part
We're removing all parts from the exterior of the Airstream in preparation for polishing. One of the parts we've removed is one that I'd never understood -- and still don't.
PICTURE 1: This part was attached to the outside aluminum of the rig with rivets just above the battery compartment. The first picture below shows what it looks like from the outside. (That's paper background, standing in for the aluminum.) You can see that it has a small shelf of sorts, hole in the center below. After cleaning out prehistoric gook, I discovered what appears to be a threaded inside.
PICTURE 2: On the inside of the exterior aluminum, the part has a nipple, to which is connected a plastic hose that leads down through the wall and into the battery compartment. There is nothing in the hose (except some dirt).
PICTURE 3: This is the part in profile as removed from the Airstream. (On edit, I just noticed that I reinstalled the hose upside down, so the aluminum part should be rotated 180 degrees.)
So what the heck is this?
Lynn
PS: Please excuse the quality of that last pic. Obviously, I'm having trouble switching from a DSLR to a point-and-shoot.
WBCCI 21043
Old 04-22-2013, 08:46 PM   #2
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Vent for battery. Shelf provided a break so rain water would not run into vent hose.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
Old 04-22-2013, 08:49 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
If that's a battery vent, it's tiny! The inside of that plastic hose is 1/4 inch.
Lynn
WBCCI 21043
Old 04-22-2013, 08:54 PM   #4
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Older ( not low maintenance ) batteries would have had a nipple that small hose slipped on to. I seem to recall most batteries had them around the mid eighties or before.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
Old 04-22-2013, 08:58 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Then I'd think that the battery would be in some kind of box arrangement to capture off-gassing and lead it out? Also, any idea on why the inside of the part would be threaded?
Lynn
WBCCI 21043
Old 04-22-2013, 09:03 PM   #6
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Pre-Nader days didn't have the safety concerns of today, but the regular batteries would pop their cell caps without the vent on the battery. Audi's of that era and later had batteries mounted below the rear seat and had a similar arrangement to vent to the outside.
Not sure on the threading on the inside. I hadn't noticed that on mine.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
Old 04-22-2013, 09:40 PM   #7
Lynn
Lynn.
That plate held the vent hose for the battery.
The batteries back then had a plastic cover that covered just the top of the battery and was held in place with the battery hold down bolts.
Old 04-22-2013, 10:07 PM   #8
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Ok, so I guess the mystery is solved!
I'll reinstall the part after the polish job. Not that it does that much, but there are three holes to cover (two rivet holes plus the larger nipple hole), and the outer part does so nicely.
This job is going to take a number of weeks, in good measure because we still don't have decent outside work weather every day. April in the high mountains are sometimes nice, but, well, for example, tomorrow it's supposed to snow.
Lynn
WBCCI 21043
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Airstream Rental for Airstream Owners ONLY jverduzco Airstream Lifestyle 34 12-26-2012 12:18 PM
Where not to buy an airstream scorpiontimo Off Topic Forum 25 04-27-2011 05:09 AM
