Old 04-18-2015, 07:00 AM   #1
1966 30' Sovereign
CONCHO , Arizona
66 30' black water tank replacement
I have a 66 airstream and need to replace the black water tank. Is this from done from the inside, or do i open the belly wrap. Several years ago i replaced the toilet. Modified by removing the fiberglass around the toilet. Moved the battery and replaced the copper water lines with pex pipe.
Any help will be appreciated. Thank you.
AZVINTAGEAIR is offline   Reply With Quote
Black water tank replacement '74 Land Yacht rear bath bhutch74ly Plumbing - Systems & Fixtures 27 06-23-2016 09:56 AM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Black Water Tank Replacement Problem Larry71 Waste Systems, Tanks & Totes 9 04-19-2008 12:24 PM
Black Water Tank Replacement 1970 31' Sovereign sgttibbs Waste Systems, Tanks & Totes 1 09-28-2004 02:57 PM
