Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-15-2008, 11:57 PM   #1
GreenApple
GreenApple's Avatar
Profile:  1973 31' Sovereign
St. Marys , Ontario
Images: 16
31' 73 sovereign - Where to begin?
Just bought my first Airstream! I have a narrow time frame (6 weeks) to get this trailer ready for the summer season, during which I will be fulltiming. I am lucky enough to be able to devote almost all of my time to getting it ready, and have the benefit of a handi-man father who is also willing to make this project a priority.
My question is: Where do I begin? It looks to me that the windows have been leaking because the floors are wet under them, I haven't checked the plumbing at all, and the interior could use some "modernization" and serious cleaning. All this and I haven't even talked about the peeling clearcoat, nor looked at the undercarriage (although I won't be covering a ton of miles right away)... On a good note, I checked for rear-end separation and it didn't look too bad, and besides the clearcoat the shell looks really good.
Hopefully the pictures can aid some of you experts in guiding me as to where to spend most of my time now, and what can wait until next winter.
Name:	P1100183 (Medium).JPG
ID:	52584   Click image for larger version
Name:	P1100210 (Medium).JPG
Name:	P1100185 (Medium).JPG
ID:	52586   Click image for larger version
Name:	P1100204 (Medium).JPG
Name:	P1100188 (Medium).JPG
ID:	52588   Click image for larger version
Name:	P1100189 (Medium).JPG
Name:	P1100186 (Medium).JPG
ID:	52590   Click image for larger version
Name:	P1100197 (Medium).JPG
Name:	P1100219 (Medium).JPG
ID:	52592   Click image for larger version
Name:	P1100217 (Medium).JPG
GreenApple is offline   Reply With Quote
Old 01-16-2008, 12:29 AM   #2
Jim Foster
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
Walnut Grove , California
Start with the leaks
First thing, fix the leaks and get that floor dried out. If you have rot or dry-rot that portion of the floor must be replaced.
If you merely have "weathering" due to the water, there is an easy way to repair that.
The wood must be dry....Use five minute epoxy that comes in the double tubes. Empty the tubes in a paper bowl. Pour in about two "glugs" of denatured alcohol and stir the mixture well. It will be thin like water. Pour it over the "weathered" area. It will soak in quite nicely. The alcohol will evaporate, then the epoxy will get hard. The next day the area can be sanded and finished as you wish.
One of those double tubes will do about 6" x 8". It doesn't go very far, but is much easier than other methods.
I used this little trick on the floor inside the door in our Caravel. I think it took three tubes. It works.
Remember,....This is for weather checked areas ONLY.
NOT for ROT.
Old 01-16-2008, 05:11 AM   #3
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
With that much water damage I would use fiberglass cloth and resin and do the whole floor.
But where there is dry rot, which you can test for after it's completly dried out, you will need to replace parts of the floor.
I would also drop the belly pans all the pink insulation is likely soaked and will need to be removed.
You can then look for any frame rust.
If it were mine I would remove as much of the interior as I could to get to it all.
The floor and all this will take 2-4 weeks.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 01-16-2008, 05:29 AM   #4
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
First, and most important, remember to breathe
No doubt you will get information overload with answers to your question
My $.02
Personal safety first, trailer safety second, all the rest are details:
1.propane
2.electricity
3.brakes, axles, tires, and hitch
4.running lights
As far as the floor, wish I tried that thinned out epoxy trick. I didn't but it sounds like it may be worth a try. There are several (more expensive) penetrating epoxy resin products out there that will restore punky wood but rotten wood will have to go. I used a product called Rot Doctor or something like that with real good results.
Like a couple of Balboas we headed into the wild pavement of yonder with a monstous piece of aluminum hooked to our rear end. "The Long, Long Trailer".
Old 01-16-2008, 05:51 AM   #5
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Be sure to check inside the rear storage compartment for more rot...almost every Airstream of this era has problems there. The other areas are pretty typical as well.
I agree with Lumatic that your axles are most likely shot. (I know, does the good news ever stop!?!).
Congrats and good luck with your new find!
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 01-16-2008, 08:37 AM   #6
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
I noticed in the photo of the rear window, there seems to be "spots" above the rear window, probably where an awning ws attached. Are those holes, or is there something in them? If they have something in them, you should probably dab something on them to make sure they don't leak water.
Our Sovereign had water in the rear compartment floor, and you can't see it unless you remove the aluminum cover so you can see the floor. This is the usual cause of the rear sag in that year trailer.
The other spots of wet wood are usual for that model, and need to be taken care of soon. If the floor has started to get soft in those areas, you can get some Rot Doctor to stabilise it.
Old 01-16-2008, 09:20 AM   #7
Lothlorian
Profile:  1973 27' Overlander
Loganville , Georgia
Several weeks ahead of you
I joined this forum seveal weeks ago and it has been very helpful. I am not a seasoned talented mechanic or an experienced RV restorer. This has been a real learning experience for me and my wife. At first we were disappointed that we had challenging problems, but this has turned into a very fun project that we both as a married couple are enjoying doing together. We are into it! The information in here has me way ahead of my projected schedule. I am trying to get ready for the vacation season. I am going to and I suspect you will have to replace parts. I am making a big list and then I plan on ordering all the stuff at once. Here is my project. http://www.airforums.com/forums/f36/...ion-38204.html
I will say things I have used. Abatron wood epoxy. Great for small dry rot spots. I tore the bathroom apart and I am doing the whole back end. I suspect that is where you need to go first. I also took my stove top and had it powder coated. I bought a new converter (30 amp) and took the univolt fuse box and had that added to it. Everything I have done is already has been done by these very knowledgable and talented people in this forum.
Lothlorian is offline   Reply With Quote
Old 01-19-2008, 11:46 PM   #8
GreenApple
GreenApple's Avatar
St. Marys , Ontario
Images: 16
Update...
First of all, I would like to thank everyone for there advice, it gave us some great ideas about where to focus our efforts.
After a few solid days of work I have to say I am pleasently surprised with the trailer. The floor has dried up quite well, the pictures were taken after a week of rain and melting snow. Removed much of the inner furniture and only found a couple of very small rotten spots. We scraped out anything we could and filled with epoxy body filler with fiberglass in it. The other spots we will try the thinned out epoxy trick. The rear storage only had about an inch of rot right at the back edge, otherwise looked dry. We removed some of the inner skin pieces, and it was dry.
The propane was checked at the dealership before the sale was completed and we will check the electrical this week. along with finding and sealing the leaks.
I have a question about the axels, and I think I know what the answer will be... With the weight lifted off the wheels, the arm off the axel is in the "neutral" position. When we jack from the hub to check the travel in the axel there is a couple inches of travel, will this suffice, or is it time to get new axels?
I will post some updated pictures within the next few days...
Old 01-19-2008, 11:58 PM   #9
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The torsion arm, as it goes rearward, should have a downward angle of about 10 degrees, with the trailer loaded and the tires on the ground.
If the torsion arm angle is zero, with no weight on the tires, then the axles are finished.
If you traveled with them, the trailer will bottom out everytime you hit a bump.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 01-20-2008, 01:12 AM   #10
Reganzo
Profile:  1988 34' Limited
Stewartsville , New Jersey
wet spots on floor
I too have discovered floor problems in my 88 limited. Some were so bad I replaced with marine plywood. I have some very small areas that are wet, but solid when smacked with a hammer. Some of you mentioned a product called rot doctor, where do you get this?
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 01-20-2008, 06:02 AM   #11
PizzaChop
PizzaChop's Avatar
Danielsville , Georgia
Images: 197
Here's the link to some stuff I used on a boat transom. CPES by Rot Doctor
It's not cheap...
I like Jim's idea and even wonder if you couldn't use just regular epoxy (Evercoat, or the like) and thin it with acetone so that it penetrates the wood.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 01-20-2008, 07:51 AM   #12
overlander63
Rivet Masher
L.A. , California
Regards,
Reganzo
I got Rot Doctor for our floor at West Marine. Most "big box" boat stores will have it. If you wind up with a salesperson like the one I was saddled with, it is usually carried in the paint aisle.
Replacing a Univolt in a 31' International wacnstac Electrical - Systems, Generators, Batteries & Solar 9 09-07-2006 10:39 AM
'69 International Land Yacht 31' price jkludt 1969 Overlander 5 09-07-2006 08:03 AM
79 31' International partial floor replacement wacnstac Repairing/Replacing Floor &/or Frame 25 04-11-2006 09:40 PM
70 International 31' Bfrank For Sale & Wanted 0 07-07-2004 08:05 AM
