06-08-2019, 12:59 PM
#21
2019 25' International
Washington
, Washington, D.C.
You’re under warranty- trip to jackson Center?
06-09-2019, 04:20 AM
#22
2012 27' Flying Cloud
W
, New England
If addressed to me, I’m well past warranty and while I’m planning a trip to JC next summer for a bunch of stuff, I won’t wait that long for this issue which seems solvable given all the great advice here. On a 10 point scale this doesn’t rate a 1 for me [emoji3] - but very grateful for all the advice.
I’m really curious about the piano hinge idea....
06-09-2019, 04:29 AM
#23
W
, New England
Originally Posted by RFP
Wow, "foam" door? Really?
I didn’t write that one but I can tell you that autocorrect does weird things. If he was typing curved form door and has a letter wrong, “foam” could be the auto-result. Happens to me a lot. And if I catch them early enough I fix them. Otherwise, I have tons of posts here that sound far more ill-informed than I already am [emoji3]
06-09-2019, 06:47 AM
#24
2016 27' Flying Cloud
Labelle
[ATTACH] [/ATTACH]
If I attached the images properly you can see the piano hinges I put on sink doors. I used a standard 30" hinge that I bought at Home Depot or Lowes. I fastened the hinge to the door first then I used 3M VHB tape to attach to the cabinet while putting the screws in. Yes you can see the hinge edge with the cabinet closed. That was my wife's concern but to us it is a non issue. Doors open at least as wide as the stock hinges and there is no hinge getting in the way putting item inside or taking out. I like the free access that I am replacing the hinges in the small cabinets beside the queen bed. Clothing is always catching on the hinges. But here the fit is too tight and the door needs to be trimmed to make it fit and the door operate properly.
Bill
2016 Flying Cloud FB
2014 Ram 3500 4x4 extended cab
06-09-2019, 08:47 AM
#25
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
The May issue of Blue Beret has a tech article on these.....
06-09-2019, 10:22 AM
#26
2017 25' Flying Cloud
Lawn Guyland
, New York
Originally Posted by VTSafari
[ATTACH] Attachment 342857[/ATTACH]
That looks like the answer to me.
One last question - does the flat part of the hinge (that gets screwed to the door and to the cabinet) protrude from the edge of the cabinet thickness at all?
Walt
WBCCI - 29375
06-09-2019, 11:57 AM
#27
W
, New England
VT Safari - wow! That looks great! I think the spine on the outside actually looks kind of cool!!
I think this is the direction I’m going to take. Finding time is the only thing stopping me for now. Very very cool.
And I’m betting my DW would be able to craft something (she’s a potter) to fill those holes that look like sideways Mickeys....
Even if not - I really like that solution a lot!! Thanks for posting pics!
06-09-2019, 12:57 PM
#28
Labelle
"One last question - does the flat part of the hinge (that gets screwed to the door and to the cabinet) protrude from the edge of the cabinet thickness at all?"
You can get different widths of piano hinge. I think I got 1/2" and it definitely wasn't a problem. So I just measured my cabinet walls and door thickness. My doors are 5/8" thick. The cabinet wall thickness toward the door is 3/4" and the cabinet wall towards the rest of the cabinets is 1/2". So 1/2" hinge will not extend past any cabinet wall thickness or door thickness.
Bill
06-09-2019, 03:25 PM
#29
W
, New England
I am still going to do the piano hinges ... but ....
As luck would have it - on the ride back from Liberty Marina (what a gorgeous weekend in NYC! - and if you can get to the Met to see the Play it Loud exhibition - it is outstanding - I squirted a few just seeing Stevie Ray Vaughn’s Fender.....) the cabinet door popped off the top hinge (remained connected to the bottom hinge).
I could clearly see the back part of the hinge that connects to the metal bracket that is on the wall portion. The two screws holding THAT part in place (not visible from the pic I posted) were VERY loose. So - I grabbed some Loctite red out of the toolbox, applied to that and the bottom one as well since I took the cabinet door off, re-tightened the screws and popped the door back on. Perfect! So for now - let’s see how that does. Maybe the piano hinges are a nice winter project there, on the nightstands, maybe the hall closet....at least for today, it’s perfectly functional! [emoji3]
03-15-2021, 12:48 PM
#30
Eric
2019 25' Flying Cloud
tucson
Part Number Info Request
Originally Posted by Piggy Bank
Actually these hinges DO release the door from the cabinet quite easily. That is OK.
If the door comes off, then you can just re-snap-on the hinge half on the door to the hinge half on the cabinet face.
Google Blum Hinge Adjustments to see in action how these work. Here is one I found:
https://www.google.com/url?sa=t&rct=...ZdiWR_oz7Dsc5O
Hi .. trying to find part number for the sink door hinge .. i thought ordered the correct part .381607-10/11 .. but this is only the door side .. not the frame side which is like a "cross" .. any help will be highly appreciated..thank you!
08-17-2021, 05:09 PM
#31
Woodway
Blum Inertia hinges
Prepping for a camping trip and found sink cabinet hinges loose. Again...
Spent an afternoon removing the junky nylon screw anchors from the R cabinet door, slightly tapping out the hole and inserting a flush-fit piece of oak dowel. Screws are nice and tight now like the ones I did on the L side a couple of years ago. Given the amount of weight leverage imposes on these curved doors, I wonder why AS didn't use three vs two.
Saw the YouTube video on the Blum Inertia hinges and wondering if these are direct fit replacements for the fidgety/finicky Grass ones we have now.
08-17-2021, 05:18 PM
#32
2019 27' Flying Cloud
Kansas City
, Missouri
Pound of cure for an ounce of prevention.
Now that you have things put back together, go the extra mile and secure the hinges with zip ties. Circle around the whole thing.
I did that this spring. Now even if they pop off the screw, they stay in place.
Piggy Bank
08-18-2021, 06:50 AM
#33
Washington
, Washington, D.C.
I have the curved doors under the sink. I duct tape them when traveling to ensure they stay closed. To re-use the tape (I use a fairly long strip), I 'softly' lay it around my trash can. It comes right off again for next use on the doors.
08-18-2021, 08:23 AM
#34
2016 27' International
Sherwood Park
, Alberta
I used to use duct tape as well, but I found this and have been using it ever since for the curved sink cabinet doors, among other things, when we are travelling. Holds well, reusable, and no tape residue on the cabinet door.
08-19-2021, 06:44 AM
#35
Woodway
Sink Cabinet Door Hinges
More good solutions; thanks! we use a tarp bungee--one of those elastic cords with both ends thru a plastic ball--threaded thru the door handles to keep things corralled. But eventually the screws seem to work themselves out a bit. OTOH, those doors probably get more use than any other.
Subbing the dowels for the plastic anchors remedies the screw problem but a couple of the hinges are starting to get a little sloppy internally. Found a template for the Blum and it looks pretty close to the Grass version. May have to order a pair just to see how things line up.
11-15-2023, 08:04 AM
#36
tucson
door hinge replacment
The grass hinges are no longer available for these doors and wondered what hinges are available that will work. thanks
