2009 23FB Flying Cloud
On a recent trip we noticed our radio no longer powered on. While trying to figure out what was going on I noticed the
12V outlet next to the radio didn't have power either.
I checked the fuse (and all fuses) at the control panel and even switched the radio fuse with others; it's fine. Test meter from the fuse to ground shows me 12+ volts so the circuit seems good, just like all the other circuits on the panel. That circuit is a thicker gray wire which heads out through a conduit under the belly of the trailer, and I can see it with a bunch of other wires under the dinette seat when it enters into the wall. Inside the cabinet housing the radio where the wires enter there are 2 gray wires one of which goes to the radio harness and one goes to the
12V socket. Neither have power.
Anyone know of a slick way to figure out what's happening here?
Also, I did find the additional fuse in the back of the radio under where the wiring harness plugs in and it's fine too.
All suggestions will be gratefully investigated.
Thanks!
