Old 06-23-2014, 11:13 AM   #1
AtomicDame's Avatar
1967 26' Overlander
rsm , California
20 Year Old Mice? Wheel covers?
We are finally at the stage when we're taking off the wall panels and redoing the nitty gritty. We removed the plastic tire coverings (by the way, can you buy repacements?) and noticed a lot of super old mouse droppings. We had our pink respirators on, and promptly bought haz mat suits. Is this necessary?
AtomicDame is offline   Reply With Quote
Old 06-23-2014, 12:03 PM   #2
r carl's Avatar
Lin , Ne
Be sure to run the vacuum canister outside the camper.
Old 06-23-2014, 12:06 PM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Keep the masks on when emptying the vacuum sweeper. Sterilize the inside of the vacuum sweeper when done. A strong disinfectant is needed to wipe down all areas where there is mouse residue.
Old 06-23-2014, 12:08 PM   #4
richw46's Avatar
Lexington , Kentucky
Working inside the walls you're going to encounter all kinds of stuff but I wouldn't think you'd need a hazmat suit, coveralls maybe. You should wear a dust mask / respirator. I don't know what was used as insulation in those older models but you wouldn't want to be inhaling it.
How do you know the droppings are 20 years old? Maybe they're just a month
Good luck on your restoration. I'm happy to just have to maintain one of these things.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-23-2014, 12:15 PM   #5
richw46's Avatar
I had a conversation with an EPA guy several years ago when I was taking up old floor tile in my kitchen. He said it may contain asbestos and to not use a vacuum because it can pass through the filter, go into the air and get breathed in. His advise was to use a broom and gently sweep into a dust pan, then dispose of it.
If it's possible to use a shop vac with a long hose and keep the base unit outside the trailer to avoid a similar situation, that might be best way to keep the airborne dust at a minimum.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 06-24-2014, 10:41 AM   #6
1993 25' Excella
CLeveland , Ohio
Wear a dust mask and gloves. Shop vac outside of the AS. No reason to go overboard.
Akronguy is offline   Reply With Quote
Old 06-24-2014, 12:48 PM   #7
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
It's not asbestos you should be worried about. You should be worried about hantavirus. It's spend by rodents in their excrement. I know a guy who died of it.
Seriously.
Google it for more info from the CDC.
Old 06-24-2014, 01:00 PM   #8
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I used a respirator when doing my resto. You really don't want to breath in any of that stuff. I got one like this with replaceable cartridges.
I don't know about replacement interior wheel wells. Mine were very brittle. I patched them up with some sturdy duct tape
Stephanie
Old 06-24-2014, 01:35 PM   #9
richw46's Avatar
Sorry if I mislead you, my point is that a vacuum cleaner can spread dust, bacteria, etc. because it passes through the vacuum's bag and into the atmosphere. It's better to carefully sweep it, maybe spray it down first to prevent it from going airborne. I didn't mean that there would be asbestos in the trailer.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 06-24-2014, 02:07 PM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Rich - well clarified! Plus low tech solutions are often the easier way to do the job. Even with HEPA filters stuff will get tracked out on your shoes, leak out an unnoticed pin hole in the hose, etc.
Pick up the big stuff, gently brush down most of the rest, wipe down and use bleach or other disinfectant. I might throw a layer of paint over an affected floor. Booties might be a good idea to keep from tracking the stuff OUT Of the trailer.
Paula
Foiled Again is online now   Reply With Quote
Old 06-24-2014, 02:28 PM   #11
2014 23' Flying Cloud
Reed Point , Montana
Spray with bleach mixture and mop, don't use a vacuum or broom.
Bigskyrider8 is offline   Reply With Quote
Old 06-24-2014, 02:55 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
http://www.cdc.gov/hantavirus/survei...-exposure.html
Not to minimize an awful disease, but the way I read this there were 640 recorded cases of this for all time in the whole nation.
That said, I think about this disease when I clean mouse poop, but I will have to admit to not pursuing action apart from really washing my hands a lot. I had a job that for many years meant dealing with other people mouse infested homes and belongings. I didn't have time to take extraordinary measures.
The odds are quite low indeed apart from the western states of contracting this disease.
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
Vent covers and outside propane covers robwok 1960 - 1964 Overlander 4 02-09-2011 11:56 AM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 03:34 PM
Mice, Mice, Mice Jake General Interior Topics 21 12-01-2009 12:09 PM
Engine/Year Trans/Year Matrix ViewRVs Mechanics Corner - Engines, Transmission & More... 36 10-23-2005 07:40 PM
