Old 09-02-2008, 04:32 PM   #1
Rapid City , South Dakota
2 Quick (I hope!) Questions
1. What tool/procedure do you all use to remove the remaining 1/4" stub from Olympic rivets?
2. My old '60 Streamline's interior has LOTS of crappy latex (!!!) paint slopped all over. I'm thinking of sand blasting with some media other than sand. Any ideas/suggestions?
Thanks to all of you for your help.
mheilmann is offline   Reply With Quote
Old 09-02-2008, 04:46 PM   #2
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
I don't know about the latex removal. But I used one of these for the rivets. Olympic HS310-5B Rivet Head Shaver
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 09-02-2008, 04:55 PM   #3
Images: 14
Don't blast it
My recommendation would be not to blast it. I have seen an Airstream that had the interior paint removed by soda blasting. It took the paint off but left an impossible to clean mess. Soda penetrated every crevice and filled the cavity between the skins. The interior skins will have to be removed to clean up all the left over media.
Also if you proceed, be sure to use the lowest possible air pressure. It is easy to warp the thin aluminum as you blast it.
bjond is offline   Reply With Quote
Old 09-02-2008, 05:45 PM   #4
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
you may want to look into dry-ice blasting no nasty residue to clean up,but it will not be cheap.
Rollerboy is offline   Reply With Quote
Old 09-02-2008, 06:04 PM   #5
2009 27' FB International
Silsbee , Texas
A Friend of mine had a Antique Car blasted with plastic pellets for a cleaner and easier on the old metal job. This was in Houston Texas years ago. Maybe a Goggle search might turn up shops that still do that?
Craig Schrader is offline   Reply With Quote
Old 09-02-2008, 06:32 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We use a rivet shaver as well...but if you have only a few to do, you can do them with a Dremel or Foredom tool - or even a file. Cut the shank down first as close to the rivet head as possible, then shave them. It helps keep the tool from hooking up on the shank &/or jumping off the rivet and marring the skin. There is a "special tool" for trimming the shanks, but we just used a pair of wire cutters - worked fine.
Shari
I hope this isn't too political... Minnie's Mate Off Topic Forum 16 07-29-2008 07:39 PM
Any Hope for this thing?? cem2525 Waste Systems, Tanks & Totes 1 06-02-2008 01:17 AM
some needed help i hope toronto Member Introductions 3 02-27-2007 08:59 PM
questions from hope to be owner moisheh Airstream Motorhome Forums 2 03-26-2004 05:48 PM
Bob Hope... canny_banjo_man Off Topic Forum 10 07-30-2003 01:43 PM
