Old 10-12-2010, 08:58 AM   #1
PKO
1987 32' Excella
Eastern Shore , Delaware
1987-32' Excella Vents & Dents
Just got an Excella w/ Suburban and excited to get to get 'er going. Couple of questions tho. I cannot find a replacement roof vent. Does anyone know where to get the roof vent that pops straight up. My old one is both plastic and metal. The only ones I see online are the hinged type. Also, there are a couple of issues outside. The storage lockers up front and in the rear are rusted out. Are there any replacements out there you know of? And there is a dent in the front port side corner. I see some 'streams with front cover panels in stainless. Are these hard to install or where can you find these? Thanks. See you on the Road! Check the pic out of my rig.
PKO is offline   Reply With Quote
Old 10-12-2010, 09:37 AM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Nice coach, we had one just like it. See if you can post the pic in a jpeg so it can be enlarged to see the details of the dent.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-12-2010, 09:53 AM   #3
PKO
1987 32' Excella
Side View of Dent
Here's a pic of the dent
Old 10-12-2010, 09:57 AM   #4
Mike Leary's Avatar
Images: 11
That does not look THAT bad since it looks like only the front panel will have to be replaced, no bondo, no repair. Good luck, hopefully Andy will come on.
Old 10-12-2010, 10:10 AM   #5
1989 29' Excella
Seattle , Washington
You can get rock guards from a number of places online, a search should find you some. From your picture it looks like the rock guard will cover the dent, if there's no damage on the inside, and it could be hidden, then no point getting it fixed, unless it really bothers you......
Streamer Dan is offline   Reply With Quote
Old 10-12-2010, 10:25 AM   #6
Rock guards are for the windows, which you already have.
You are asking about a "segment protector".
The top of that protector is about 11 inches below the rockguard, as measured on an Airstream in our shop.
Old 10-12-2010, 12:43 PM   #7
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Old Roof Vents
I believe the original metal "straight-up" Roof vents were made by Hehr.. Noisy tiny metal fan blade not very effective... No longer available, and far less effective than Fantastic Fan brand vent/fans.... Come in various models with thermostats and rain sensors and remotes, or just 3 speeds and reverse.. If you get Fantastic Fan, be prepared to ask factory for complimentary ivory plastic cuurved bezel that fits inner ceiling far better than stock flat white plastic unit...
The small tinted pop-up vent cover in bathroom is still available, from Airstream or other RV parts sources....
Condoluminum
Condoluminum is offline   Reply With Quote
Old 10-12-2010, 09:33 PM   #8
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
The segment protector would probably be a good investment even if you replace the dented panel. It could hide a good part of the dent if you don't replace the panel.
4RXLA is offline   Reply With Quote
Old 10-21-2010, 09:39 PM   #9
1988 29' Excella
Eunice , New Mexico
Need help finding vent cover 88 excella
Rv store told me that they could not get a cover for my 88 airstream, any information on this would be appreciated, I was looking for a max air or something that looks nice .
redex is offline   Reply With Quote
vent covers, dent
Value of a 1986 Excella 32' PA BAMBI II Trailer Values 1 05-04-2010 09:49 AM
1987 argosy by airstream 32' eBay Watch Airstreams on eBay 0 03-31-2010 09:50 AM
1987 argosy by airstream 32' eBay Watch Airstreams on eBay 0 03-24-2010 10:00 AM
1987 32' Excella - Solar power questions RJB54 Electrical - Systems, Generators, Batteries & Solar 3 04-10-2009 04:50 PM
Need opinon on 32' Excella 1987 George-CT 1987 - 1989 Excella 6 01-29-2004 05:29 PM
