Old 08-04-2014, 07:04 PM   #1
1974 27' Overlander
aromas , California
1974 toilet loose
Hello Helpful folks,
I have a 74 airstream and the toilet is VERY loose. I just took it off the bolts and found the metal plate that supports it is rusty and it seems perhaps the floor around the toilet is also rotting. ANY suggestions about the BEST way to repair this would be gratefully received!
path star is offline   Reply With Quote
Old 08-04-2014, 08:25 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Replace the floor and install a new toilet flange.
If it is like the one in our '74. It was made with 1/4" plywood. I built a new box over the black water tank out of 3/4" treated plywood. Installed a new toilet flange. Now it is nice and solid.
Old 08-04-2014, 10:08 PM   #3
Ottawa , ON
Huh. I thought the floors were 9/16" or 1/2" thick. Quarter inch sounds kind of light.
Old 08-04-2014, 10:25 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the toilet sits up 10" or so inches above the floor. Which is the way it is in the Argosy. It is not sitting on 3/4" plywood.
In the Argosy the black water tank is above the floor. Not sure what your coach layout is.
Old 08-04-2014, 10:28 PM   #5
Ottawa , ON
Our AS '74 Sovereign has at least 1/2" thick floors, stool sits right on the floor.
We have the rear bathroom layout.
I can't see 1/4" being able to hold up a large adult without some steel reinforcement...
Old 08-05-2014, 07:18 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like it is at least 1/2" since the toilet sits directly on the floor. Not on a platform above the floor.
New floor section, new toilet seal and flange. Look to be the order of the day.
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
1974 Sovereign Land Yacht :: 1974 Airstream Sovereign Land Yacht MyTwinkie Airstream Registry Discussions 0 01-13-2012 08:51 AM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
1974 Argosy Toilet valves buffaloman Sinks, Showers & Toilets 11 11-22-2009 09:42 PM
