Old 11-18-2015, 08:54 PM   #43
1973 25' Tradewind
Beautiful , Oregon
So for the plumbing I thought it would be fun to show the before and afters. I replaced all with PEX
What I did with the plumbing is isolate all the component parts so if anything goes wrong on the road I can turn off the valves and still use everything else until I can get home and fix it. This had its costs. The money to do it was one thing but it caused me to sit on that 5 gallon bucket a lot and scratch my head. The valves take up space and complicate matters. I donít think I am far off when I say there is almost as much plumbing in the trailer as a small house.
I took the advice of the panel pro on the VAP ( for new people, that is the Vintage Airstream Podcast, The Vintage Airstream Podcast | Vintage Trailer Restoration ) and put hot and cold drain valves in the front and back of the trailer so at the end of the season when leave for home just open them both up and let all the water drain out as you rock and roll along, to self winterize.
It all adds work but I think it will be worth it. At least I get the satisfaction of knowing I did the best job I knew how to do at the time.
So when you look at the before remember this was a pretty nice trailer. I paid a good price for it after looking for 9 months and learning what to beware of.
Notice all the valves for the reasons I mentioned above to allow me to isolate a given area for repair or continued use while on the road
Tony
ID:	252471   Click image for larger version
ID:	252473   Click image for larger version
ID:	252475   Click image for larger version
ID:	252477   Click image for larger version
Tony S is offline   Reply With Quote
Old 11-18-2015, 09:10 PM   #44
2015 30' Classic
Houston , Texas
absolutely amazing
veratipton is offline   Reply With Quote
Old 11-19-2015, 04:34 AM   #45
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Is the height of the new street-side bunk higher than original? I seem to be remembering that the original is just barely above the wheel well...looking at that new heat duct has me thinking...
I've been going back and forth on the notion of keeping the furnace, at all, because we hardly ever used it, they're expensive, and take up a lot of space.
I don't have that closet between the bunk and the shower; that's where the space difference is between Safari and Tradewind (hence, the plumbing entrance quandary that I mentioned before). I was thinking of moving it to the spot where you put your electric entrance. There was no storage compartment in that spot on the original bunk, as it housed the heat duct/outlet.
What are the electric conduits for?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-19-2015, 08:22 AM   #46
1973 25' Tradewind
Beautiful , Oregon
Chuck
The flex conduit is for a new circuit servicing both sides of the new gaucho. One is dedicated circuit for the microwave. The other one is DC for the water heater. I also had another DC line run on the curb side for the new refrigerator. The 110 was already there.
The height of bed I believe is a little higher. I wanted to accommodate 2 banks of drawers.
My wife wanted the New Furnace. She wanted it to keep the Airstream complete and fully functioning like it was originally. To keep its value. I don't know maybe for resale. Guess what I don't foresee reselling the Tradewind. Not after the work and money I put into it. Also I must say I don't know if she is right or not about having it, she is often right. I am with you it takes a lot of room up. I am sure some cold morning in Yellowstone or somewhere have that new 30,000 btu furnace blasting and think we died and went to heaven. Speaking of dying and going to heaven I am not doing the propane myself. I am off today to talk with an RV outfit I heard was good.
Tony
Old 11-19-2015, 08:22 AM   #47
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Wow, I LOVE LOVE LOVE that woodwork! Beautiful grain! One of my favorite things is that first coat of finish on wood - just pops the grain out beautifully. You have done a wonderful job! We also spent a lot of time on our trailer, but count it now as very well worth it. We really enjoy the trailer, and our fellow MN WBCCI members always point new people to our trailer as "the one to see". That alone tells us it was worth it, along with our comfort.
Chuck: we use our furnace in spring and fall. Even if you winter in Texas, Arizona, Florida they get cold snaps. You can use a space heater, but what if you don't have electric? Just playing devils advocate ...
Kay
Old 11-19-2015, 08:51 AM   #48
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Well, if you run that thing while you're boondocking in yellowstone, you may wake up and find that your battery has died and gone to heaven, instead.
They use so much electricity, unless you have a giant $olar array on the roof, you might as well consider it to require a 110v hookup....in which case, why not just use an electric heater? (my attitude, anyway).
But its IN, so its a moot point. It is nice to just turn the dial, and heat the trailer from 40 to 70F in about 5 minutes.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 11-19-2015, 12:54 PM   #49
Minno's Avatar
1972 31' Sovereign
We have 2 golf cart AGM batteries. We have boondocked with the furnace on for 5 days without battery loss. If you're losing batteries after a night, maybe you need new batteries?
Kay
Old 11-19-2015, 01:31 PM   #50
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Kay
well...MORE/bigger batteries. I think 2 6v agms are probably 4-5 times the capacity of a single group 27 wet cell, so....yeah, sounds about right.
Bigger trailers also have the room for both big furnaces, and big batteries. In these smaller units, you have to decide what is worth more--convenient heat, or storage space. no wrong answers!
Air:291
Wbcci: 3752
'73 Safari 23'
Old 11-19-2015, 04:03 PM   #51
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
Incredible work! That wood and what you have done with it is amazing. The behind the scenes woodworking plumbing and duct work is very helpful and inspirational. Thank You!
Bullit is offline   Reply With Quote
Old 11-19-2015, 05:34 PM   #52
1973 25' Tradewind
Beautiful , Oregon
Chuck, you are right about no hook ups at Yellowstone. I forgot we stayed just outside the park when we went with a tent trailer. Snowed day we arrived 7 degrees one night.
Thanks for the complements. I worry it looked like I was fishing for them. I am glad it has helped a few of you out. I have been helped so much from all the folks here. It is rewarding to know I can help others to some degree in return.
Tony
I have a few more things to post
Tony
Old 11-20-2015, 11:21 PM   #53
1973 25' Tradewind
Beautiful , Oregon
So back to some less sexy work. Had water accumulating between the double (pain) pane windows so I busted the inside one out by using some duct tape and then a punch. Its safety glass so pretty safe. You do have to worry about hitting the second one.
Other pictures: I removed the old obsolete antenna and patched it. Came out nicely, I think.
Added last picture to show results of window. Nice and clear. I actually, had bought a replacement from VTS, but didn't use it. Kept if for just incase. Also a picture of the finished patch.
Tony
ID:	252575   Click image for larger version
ID:	252577   Click image for larger version
ID:	252579   Click image for larger version
Old 11-29-2015, 06:45 PM   #54
1973 25' Tradewind
Beautiful , Oregon
Hi Folks
Thought I would show some of the latest cabinetry. Figuring out how to effectively cover the electrical system was the most difficult. Easy to see it once done but getting there was getting back on the 5 gallon bucket and think a bit.
I am happy with the result. I kept it light with mostly cedar where strength was not needed. I wanted to keep it kind of 60's kind of industrial. I think, hope, I did that. I was aware of heat build up and tried to have plenty of air circulation
Also shown is the figured cedar face to the shower pan. It allows access to some of the plumbing. It was coated with epoxy and varnished with several coats. The upper top edge had a strip of stronger mahogany glued on it.
Also shown is a cedar storage box that also stands tall to help keep shoe placed behind it in place.
So I think things are in a good place with the trailer, most everything I do is not a precursor step to something else.
Sorry the pictures are out of order. If you have any questions feel free to ask.
Tony
ID:	253047   Click image for larger version
ID:	253049   Click image for larger version
ID:	253051   Click image for larger version
ID:	253053   Click image for larger version
Old 12-03-2015, 07:18 AM   #55
Mixter's Avatar
1976 27' Overlander
Nice work! Love to watch what others are doing for ideas and inspiration. I hope to eventually post my journey.
This cracked me up. And no one understands why its taking so long
Quote by Tony S
A lot of the time on the this job is spent sitting on an upside down 5 gallon bucket, in the trailer, looking off into the near distance trying to figure out what needs to be done, what could be done, what I wanted to do and what could be done and what was I forgetting to do, and what was the implications of what I was forgetting to do. And oh, was there a better way to do it. This stuff as the over used phrase say "ainít rocket science" but the difference of a good job or bad can be out of this world,
Mixter is offline   Reply With Quote
Old 12-12-2015, 10:29 PM   #56
1973 25' Tradewind
Beautiful , Oregon
Yup, Lots of sitting on a bucket thinking. Ain't it the truth
Now I need to get working on it. I find it hard to switch back and forth between projects
Tony
Tradewind Twin 1974 - rehab/renovation BryRedWolf 1970-79 Tradewind 11 04-12-2018 07:11 AM
1973 31' Sovereign complete reno/resoration Peter77 Interior Restoration Forum 1 11-18-2013 09:12 PM
1973 rehab less than full monte Tony S Repairing/Replacing Floor &/or Frame 3 02-27-2013 08:07 AM
The end is in sight - rehab report Janet H All Argosy Trailers 16 12-06-2003 11:45 AM
6 metre interior rehab? Janet H All Argosy Trailers 2 09-24-2003 04:17 PM
