Old 08-22-2019, 04:47 PM   #1
2005 28' International CCD
Aurora , CO
05 AS Int'l Electric Brakes
The two little white wires that connect to my electric brake drum have broken off, right at the base of where they connect to the wheel. My question is, if I pop off the little rubber grommet, is there enough play in the wire that I can pull some through and splice it back together?
chrisbraypi is offline   Reply With Quote
Old 08-22-2019, 05:23 PM   #2
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Here’s a picture of the same yr 05 Intnl on inside. You should according to this.
Vantair is offline   Reply With Quote
Old 08-23-2019, 07:23 AM   #3
Aurora , CO
Thanks - that image looks like you took the tire off and opened up the brake drum housing from the outside. It appears as if there's little, if any, extra wire to pull through the back side and reconnect. Which means the only way to fix the issue would be to go through that process (which entails removing the bearing, spindle, etc.).
I was just hoping there was an easier way than disassembling the entire thing.
Old 08-23-2019, 07:51 AM   #4
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
If brake components are in good shape I bet you could just replace the magnet. Then look at magnet $$ vs complete assy $$.
GCinSC2 is offline   Reply With Quote
Old 08-23-2019, 08:32 AM   #5
A W Warn's Avatar
2000 25' Safari
If there is an inch or more, use a crimp butt connector to make the repair.
Alan
Old 08-23-2019, 04:55 PM   #6
SandKSmith's Avatar
Phoenix , Arizona
Get the butt connector that shrinks when heat is applied to it (heat gun or small lighter). The kind that shrink will help keep out the dirt & water that can corrode the connection.
Steve
SandKSmith is offline   Reply With Quote
Old 08-24-2019, 09:28 AM   #7
Vantair's Avatar
Whatever crimp solution, best solder it first then crimp over with a butt or like type and properly seal.
Don’t want to think being years down the road wondering about a potentially oxidizing crimp only connection inside of a rusting wheel assembly.
Old 08-24-2019, 10:24 AM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
On an 05, depending on service history, I bet replacing the brakes and inspecting and servicing the bearings would be a good move. Or have a shop pull that one and fix it.
Bill M. is online now   Reply With Quote
2016 Int.27 Electric Switch question rollieboy Lights - Interior & Exterior 3 04-21-2017 12:42 PM
Has anyone made int mods to a 2012 27' FB Int? Jordanparson General Interior Topics 19 05-18-2012 05:54 AM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 09:18 AM
