Old 11-19-2007, 08:59 AM   #1
kirkwood , Missouri
Wiring The Trailer Not The Tv?
I have a 2006 19' bambi. I have two TV one a 3/4 ton Dodge pu and the other a 2006 Escalade. I want to wire the AS with a electric brake modulator
with its own dedicated battery so i do not have to wire two TV.Has anyone done this? We do this all the time in our rental yard for Bobcat trailers for customers who do not have brake controllers. The system uses a programmer out of the 12v accesory port on the dash to set the gain and thats it. Any information on this appriciated. Thanks,Jeffrho
Jeffrho
Kirkwood MO.
2006 19' international Bambi ccd
owner since 11-11-2007
jeffrho is offline   Reply With Quote
Old 11-19-2007, 09:31 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
First impression that does not sound like a good idea. Even given the fact that you have a small trailer.
If you are setting the gain for the trailer at the module on the trailer you have no way to modulate the trailer brake application power once set. Most brake controllers have some means of modulating the trailer brakes either through a pendulum, program, or mechanical system. In the absence of a modulating system you only have ONE brake setting. If that is set for slow speed you will have little or no brakes at high speed. If it is set for high speed you will most likely lock the brakes at slow speed.
2004 Excursion 4x4
Trailer Umbilical Wiring pfay Lights - Interior & Exterior 6 06-09-2013 12:48 PM
Second Trailer - Wiring problem jronhunt Electrical - Systems, Generators, Batteries & Solar 2 10-15-2006 11:34 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Tow trailer wiring? Krazykraut Mechanics Corner - Engines, Transmission & More... 1 12-23-2002 09:34 AM
Our Airstream trailer wiring FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 09:43 PM
